2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-01-23T17:45:48+00:00
    Thank you michael_is_cool for the info.  My PDF extension filter was messed up and showing "Registered IFilter is not found" and I was able to fix it using your instructions.  I followed your instructions two days ago, and the filter registration is fine today (just unchecked and checked it again to make sure).
    Unfortunately, I have also stopped working on my laptop and rebooted 5 times since due to System and System interrupt CPU utilization and am getting ready to do so again (System is at ~16% and System interrupts is at ~10%, and my tablet is getting very warm).  I just checked for updates and there are none.
    But, at least some other problem was discovered and fixed ... thanks : ).
    2015-01-21T22:35:10+00:00
    I have had this same issue and I have tried everything under the sun and may have finally found the culprit after several support chats and calls, refreshes and device exchanges.  By the way- I figured this out without the help of MS Support.  Their answer is always, "let's exchange the device."  Well- I was tired of re-installing all of my programs.  I was about ready to give up on Surface Pro 3 until I tried this:
    Delete Surface Pen from Bluetooth Devices.
    I tried to just reinstall the pen driver.  And I tried to unpair the pen and re-pair the pen- and these measures did not work.  But if you remove the Surface Pen from the Bluetooth device list and do not re-pair the pen, the battery drain in sleep mode returns to normal!  I think there is something wrong with the device driver that causes the Bluetooth to stay on during sleep mode and the battery to drain abnormally.  Interestingly, you can still use the Pen (like your finger) and the selection buttons still work.  I was not able to start OneNote with the top button, but that is not a big deal for me.  The first clue for me was that the problem was completely fixed when I put the device in Airplane mode before sleep.   Turning off WiFi helped a little, but airplane mode did the trick.  Then it occurred to me that Bluetooth could be an issue, but the only blue tooth device I had was the Pen.
    Obviously, since the Pen is an important part of the Surface experience for many, this should be addressed by MS.  I would like full functionality of the pen and hopefully it can be fixed soon.  However, if you are having battery drain in sleep mode issues, this may work for you until there is a fix.
