2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-01-21T08:59:25+00:00
    Do this you guys immediately for all of your WINDOWS devices! Don't dump your precious machines just YET! This is exactly what is required to return your WINDOWS devices normal.
    http://cloudyquestions.com/2014/08/23/microsoft-windows-search-filter-host-high-cpu-on-windows-8-fixed-look-at-your-pdf-ifilter/
    Michael
    2015-01-20T22:34:36+00:00
    I have been having the same problem with the heat! And my battery seems to drain too.
