2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-10-25T03:03:49+00:00
    I can confirm that installing this driver has resolved the problem for me. I had the same issue where Sytem and System Interrupts were taking ~25% CPU when I resumed my SP3 from sleep. Working through this and other threads pointed me to the Realtek audio device. Playing sound would make the CPU drop as would disabling the device in Device Manager, but if you re-enable the device the CPU ramps back up as before.
    I installed the driver linked above and for the last 3 days I've been able to sleep and resume without the problem recurring. Many thanks for the pointer, WildSoldier!
    Cheers,
    Alan
    2014-10-24T15:01:41+00:00
    FOUND THE FIX!
    I just thought I would share with everyone my solution to this issue, touch pad issues and Wifi issues I was having.
    Here it is, as the OP of this thread after so many months of Microsoft ignoring this CPU load issue. I finally found the solution. It's called eBay, I sold my Surface Pro 3 there. That has fixed the all these unacceptable issues on this machine I paid way too much for.
