2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-10-25T12:52:02+00:00
    Looks like I spoke too soon...
    Further testing tonight shows that the problem is still there. I can sleep and resume with no problem but returning from hibernate causes our old friends System and System Interrupts to leap back to life. Disabling the Realtek audio device puts them back in their place but re-enable it and they are back.
    Looks like we are stuck with this until MSFT can find the problem and fix it... sorry for the false hope.
    Cheers,
    Alan
  2. Deleted
