2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
  1. Deleted
    2014-10-16T22:06:33+00:00
    The high CPU usage issue that has affected lots of other people, has just bitten me.
    This morning when I turned on my Surface Pro 3, i7, 256GB, it took minutes to start up, rather than the usual few seconds.  Then the fan started running continuously when the PC was just idling with no apps open.  I tried several restarts.  It now starts up quickly like usual,
    After hitting the internet and doing some research I find that I am now experiencing exactly the same issue as lots of other people, where the System and System Interrupt processes hog the CPU.
    The "System" process is running at about 15% and "System Interrupt" at about 8%.
    Just like some other people, if I play any kind of audio, the System processes CPU usage drops to 0%, but as soon as the audio stops the CPU usage quickly climbs back up to 15% + 8%.
    So I assume that there is some kind of driver issue going on.  Interestingly there are 2 "High Definition Audio Controllers" in the Device Manager.
    Is this normal?
    I checked the Update history, but the only update today and yesterday were for Windows Defender.  The last System Hardware Update was 10 days ago.
    The PC feels sluggish and unresponsive and is almost unusable.  The fan is running continuously, loud and fast, and is very distracting, and the Surface's case is hot.
    What can be done to fix this situation?  My Surface is basically unusable the way it is.
    Regards,
    Pete Hay
