2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-08-16T12:09:21+00:00
    Hello ChrisG\_NZ
    Can we get the specifics of the MicroSD card you are using?  Doing a little investigation here.
    Best regards
    Sure its a Sandisk Extreme 64GB class I, however like the other readers its not related to the MircoSD card now I think. Because its happening without the SD card inserted too.
    2014-08-16T12:07:06+00:00
    Hello OK_2,
    Thanks for sharing this question with the Community. I understand that your Surface Pro 3 uses a lot of power due to system idle and interrupt processes and that your device wakes up from sleep randomly. I'll do what I can to help you.
    We would like a little more background information. Have these issues existed since you first started using the device, or did they occur after some time? You say that you've downloaded all updates, but have you downloaded them automatically, from Start, or from desktop? Have you altered the power plan settings in any way?
    Please let us know this information so that we may further work together on your issue. I look forward to your reply.
    Best Wishes,
    Zack_T
    Hi, The issue is still present. Its been there since day one. The only way to stop it is to play music or to reset the system. But I think its connected to the sound drivers.
    It seems its only on cold boot the problems shows. So I have to boot, then reset to get a system without high CPU load. Please look into this issue asap. I see its basically the same as what the Surface Pro 2 had.
