2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-08-18T21:09:50+00:00
    Yes, of course. I have it updating every day and I check it often. I always run the latest updates, but the problem is still present.
    2014-08-18T18:32:19+00:00
    Hello ChrisG\_NZ
    Thank you.
    Hello all,
    Please ensure you have the latest updates installed and let us know if this continues.
    Best regards
