2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-08-11T09:17:56+00:00
    I got the same problem with Surface Pro 3, i5, 256GB, 8 GB - no type cover.
    I don't use any microSD Card.
    It seems that this is still the same problem with Surface 2 from this thread:
    http://answers.microsoft.com/en-us/surface/forum/surfpro2-surfupdate/surface-pro-2-high-cpu-on-resume-from-sleep/ebc0ad3d-c9ed-44c1-b6d0-a19335a4e223?page=23&tab=question&status=AllReplies
    Guys there identified following curiosity:
    Power adapter attached Type Cover attached Sleep button Wake button Resulting CPU idle <br><br>(if 25%, problem)
    Y Y Hard Hard 0%
    Y Y Hard Soft 0%
    Y Y Soft Hard 0%
    Y N Hard Hard 25%
    Y N Hard Soft 0%
    Y N Soft Hard 25%
    N Y Hard Hard 0%
    N N Hard Hard 25%
    For me there are exactly the same symptoms. When I set the system to sleep via Charms there is no load when wake up.. When I use Menu Button and wake up I got the CPU load ...
    Hope we will get an update soon ....
    Regards,
    Kai
    2014-08-10T00:21:55+00:00
    Hello ChrisG\_NZ
    Can we get the specifics of the MicroSD card you are using?  Doing a little investigation here.
    Best regards
