Same issue here as well. Surface Pro 3 + Samsung UN40H5203AF. My Surface sees the TV, and attempts to make a connection - I can see "Connecting to <COMPUTER_NAME> on the screen of my TV and then it just times out.
Surface Pro 3 does not connect to recent Samsung Series 7 TV
my Surface Pro 1 does connect well with my Samsung Smart TV series 7. However, my new Samsung Pro 3 wont connect. It finds the TV and then tries to establish connection and asks to wait - maybe the TV should not popup a PIN code - but that never happens and the connection times out. Interestingly the Surface Pro 3 gets listed in the Samsung network device settings and is set to "allowed" for connection but the Surface Pro 3 still wont connect. Note i have deployed all latest updates on Samsung TV as well as Surface Pro 3.
I would appreciate to get this working again.
Thx,
Bernd
2014-12-09T20:09:55+00:00 -
2014-12-08T11:26:52+00:00 I've got the same issue. SP3 and Samsung H6400.
Will try Airserver tomorrow, have used it before. Doesn't explain why HTC phone and Nexus work perfectly with the Samsung but SP3 doesn't.
2014-12-07T12:17:56+00:00 Folks,
There are a number of you reporting issues specifically with Samsung TV's. Have any of you tried Miracast with a different Miracast display receiver (TV)?
There's a great software receiver for Windows computers called AirServer - used to be just AirPlay for the Mac, but they've added Miracast recently. If you have a desktop or large screen laptop, you might want to look at this software (there's a 7 day trial) to see if you can connect. It's available at airserver.com. It's actually pretty neat software, too... But I'd be really interested if any of you who are failing with your Samsung TV's can connect to a computer running this Miracast software. (It's Windows certified, too).
2014-12-07T10:03:56+00:00 Same problem SP3 and samsung UE55HU8200L. SP3 see the TV but timeout first on the Tv and later on the SP3. More than 3000€... connecting by cable will be unaceptable.
2014-12-04T16:31:15+00:00 Hello, I have got the same prob. I called SP3 technical support they said me to call Samsung support and they throw the ball each other that's ridiculous...
