Samsung UE40H6270
http://www.samsung.com/de/consumer/tv-audio-video/television/led-tv/UE40H6270SSXZG
my Surface Pro 1 does connect well with my Samsung Smart TV series 7. However, my new Samsung Pro 3 wont connect. It finds the TV and then tries to establish connection and asks to wait - maybe the TV should not popup a PIN code - but that never happens and the connection times out. Interestingly the Surface Pro 3 gets listed in the Samsung network device settings and is set to "allowed" for connection but the Surface Pro 3 still wont connect. Note i have deployed all latest updates on Samsung TV as well as Surface Pro 3.
I would appreciate to get this working again.
Thx,
Bernd
Can ALL of you that are unable to connect with a Samsung/Sharp/Sony TV that supports Miracast please reply with the exact model number and if possible a link to the TV on the vendor's website? This is what engineering needs.
UE48HU7500L http://www.samsung.com/es/consumer/av/televisions/plano/UE48HU7500LXXC
Neither using wifi nor ethernet.
Fingers crossed they find a fix :)
I pretty much doubt that the surface is on the market for over a year and its still not really working :/ maybe windows 10 will bring us joy
Hi
It's a samsung UE48HU7500TXXU
http://www.samsung.com/uk/consumer/tv-audio-video/televisions/flat-tvs/UE48HU7500TXXU
Samsung UE40H6400
http://www.samsung.com/uk/consumer/tv-audio-video/televisions/flat-tvs/UE40H6400AKXXU
Thanks for your efforts!
