Surface Pro 7 camera doesn't work and light always on until reboot
2020-05-11T05:55:28+00:00
Hello! I have Surface Pro 7 i3 4/128 Gb. Camera works several times for Windows Hello and then stops, camera light always on until reboot. I have all updates.
I tried:
  1. uninstall camera in Device Manager;
  2. check and uncheck camera in UEFI;
  3. fresh start and reset;
  4. reinstall Windows with MediaCreationTool1909.
The last method helped me for a week, camera light stopped turns on for Windows Hello (only IR camera turned on) and camera worked. Now camera turns on again and stops after 2-10 times. How to fix it?
Surface | Surface Pro | Sound and camera
    2020-09-15T00:58:54+00:00
    Hi Janette, this is happening to all of us. Same problem. Please escalate.
    2020-09-13T13:44:08+00:00
    Just bought a new Surface Pro 7 and having the same problem.  Need a fix.
    2020-09-07T15:05:40+00:00
    Same issue here with Surface Pro 7. Please escalate and fix!
    2020-09-02T16:00:28+00:00
    I am also having this issue. Is this a hardware issue with some tablets or is it a software issue with all of them?
    If it helps, since the latest driver update, this problem occurs much less frequently, but I am getting fairly regular blue-screens. The error codes are: "FAULTY_HARDWARE_CORRUPTED_PAGE" and "page_fault_in_nonpaged_area".
    2020-08-13T11:10:14+00:00
    I’m having the same issue.
