Same here.
Surface Pro 7 camera doesn't work and light always on until reboot
Hello! I have Surface Pro 7 i3 4/128 Gb. Camera works several times for Windows Hello and then stops, camera light always on until reboot. I have all updates.
I tried:
- uninstall camera in Device Manager;
- check and uncheck camera in UEFI;
- fresh start and reset;
- reinstall Windows with MediaCreationTool1909.
The last method helped me for a week, camera light stopped turns on for Windows Hello (only IR camera turned on) and camera worked. Now camera turns on again and stops after 2-10 times. How to fix it?
Surface | Surface Pro | Sound and camera
2021-04-14T21:06:36+00:00
