Anyone having issues powering on their Surface Book 2?
2018-01-31T22:27:25+00:00
I am having issues the past couple weeks powering on my Surface Book 2 via the power button. It does not respond unless I eject the tablet half from the base and then press the power button. No setting or software changes except the Surface firmware update for Meltdown/Spectre a couple weeks ago. I'd say 1 out of every 5 attempts of me powering on results in a hard reboot and losing everything I had open. This is extremely frustrating! PS. I typically hibernate my PC. Would be great to hear from others that have applied the latest firmware and hibernate, if possible.
    2019-02-22T16:41:01+00:00
    This post is on target. Purchased the Surface Laptop 2 and it keeps shutting down, then I keep trying to power up and it takes forever to get it going. I disconnected it from docking station and no improvement. Disappointed in quality of product, my ten year old HP was more reliable.
    2019-02-20T23:56:31+00:00
    I dont think it’s the button also. If it was the button it wouldn’t power on if I disconnect it from the keyboard. My SB2 will not power on if its connected to the keyboard but once I disconnect it, it powers on right away every single time. That is my solution because I am tired of taking it to the MS store and the tech telling me I need a new one. I’ve gone through the process 3 times already, I’m on my 4th SB2.
    2019-02-20T07:41:23+00:00
    It doesn't seem to be the start up process issue, but rather the physical button on the outside of the machine itself. The button kinda barely clicks similar to the way a mouse clicks. It does not depress with a lot of movement like a key stroke on a typical keyboard. My theory is that sometimes you push the button and the computer does not register that you actually pushed the button. So then you push it again a minute later after realizing nothing happened. And then again a minute later after that. Sometimes I press and hold it for three seconds just negate any chance of it being user error by not pushing it in all the way. End result is i use it everyday for work and it NEVER turns on the first time i push the button down no matter if i press and hold or not.
    2019-02-19T21:51:54+00:00
    I'm having the same problem. It takes me 30mins to start up my machine. It's a joke. I thought Microsoft lifted their game.
    I should've bought a Mac book pro
    2018-12-29T13:07:24+00:00
    Hi, any solution of this problem? Im having the same.
