Battery Degradtion : Surface Pro (5 , 2017) (I5, 256 gb)
2019-06-15T07:08:49+00:00
I just wonder if some of you who own this version of Surface Pro have the same issues like mine as in below:
ISSUE: Battery at full charge drastically degraded and swingsConditions observed lately:-The battery runs out within 1-2 hrs just by browsing websites/Youtube (tested on both Chrome&M. Edge)
-To fully Charge, takes only around 20-30mins (Est. full charge not accurate)
-Battery sometimes drops by a ridiculous amount E.G. by 20-30% in 1 sec.After checked with Battert Report run in CMDAt Designed Cap at : 45,000,
My Full Charge history as below (Noted that i tried to reset the windows and all previous history is gone so this is what i remember)
First bought (Jan,2018)
Full Charge 2018                                 : around 40,000 0 44,000
Full Charge 2019(Early months)          : Starting to drop to 35,000
Full Chrage as of the last few months : 25,000
Full charge as the last few days of notice: Swings from 22,000 to 9,000 life cycles at 383
Now i cant use it outside without charger. This is very frustating while working**.**
As my device is out of warranty, after searching online, the onl way is replacement at 500USD which seems ridiculus to me just because of battery. I bought this expensive device for the reason of long-term use. this is just a year and a half. Shouldn't it last for 4-5 years for its price?
If you have the same issues and any solutions/suggestions, feel free to share and discuss.
**Update 1 8/19/19:**I can't turn on. I lost my files those i didn't back up. I don't have any other computer to use.
Update 2 8/22/19: I just bought a new PC just to work. I cant wait for 1-2 weeks (Send to another country as  there's no microsoft HQ in Thailand) and spend 500USD for just battery replacement.
I kinda gave up and thought it was my fault back then. Now, if you have the same problems. Please up vote.
Update 3 9/1/19:
Seems like my battery is completely dead after testing at a computer shop.
Conclusion:
I am not a hardcore user. In less than 400 cycles, battery (all 4 cells) is dead.
The battery life of my surface pro lasted less than 2 years.
That means you have to pay 500 USD every 2 years. (Could have used this money to upgrade lol)
Maybe 2 in 1 tablets/laptops are not ready for practical use.
Maybe other brands are geting better.
Why do we have to refurbish/replace the device for just a battery which shouldn't cost more than 50 USD.
P.S.
For those who cant even turn the device on,
It's either the circuit is broken duee to defect/unfunctional battary
OR
The battery is completely dead
Worst case = both.
    2019-12-24T10:44:49+00:00
    Yes, I have exactly the same problem and have never been able to communicate directly with microsoft about it. I love this computer, but will never buy one again unless I receive some kind of response from them. It is absolutely unacceptable. I need this computer for my work, but it doesn't work! I hate it!
  2. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2019-12-24T10:16:02+00:00
    2019-12-24T01:10:30+00:00
    Same problem.  Battery going bad at only 197 cycles.  All updates applied.  Removed driver and reinstalled.  Non-removable batteries good for about 2 years makes for a very expensive laptop.
    Battery report
    https://1drv.ms/u/s!AkIGbWA-tH1Gkvkm8FXMOP3hym3mgw
    Feedback Hub
    https://aka.ms/AA6w83d
    FULL CHARGE CAPACITY 25,720 mWh
    CYCLE COUNT 197
    2019-10-29T16:11:03+00:00
    One more failing Surface Pro battery here. Mine died in 26 minutes yesterday. It wouldn't turn back on after an hour on my Surface Dock. It only came back once I moved it to my travel charger.
    Surface Pro 5
    i7-7660U @2.5GHz
    8 GB RAM
    256 GB HD
  5. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2019-09-25T10:28:32+00:00
    All you can do is exchange it. If you are in the US you should go to the closest
    physical retail Microsoft Store (there are also 5 stores in Canada and 1 each in
    London, UK and Sydney, AU) https://www.microsoft.com/en-us/store/locations/find-a-store - if you are not
    able to get to a store, contact support
    https://support.microsoft.com/en-us/help/4051701/global-customer-service-phone-numbers.
    Go to a Store if you can, it is the best option.
