Link to my feedback hub report...
Battery Degradtion : Surface Pro (5 , 2017) (I5, 256 gb)
I just wonder if some of you who own this version of Surface Pro have the same issues like mine as in below:
ISSUE: Battery at full charge drastically degraded and swingsConditions observed lately:-The battery runs out within 1-2 hrs just by browsing websites/Youtube (tested on both Chrome&M. Edge)
-To fully Charge, takes only around 20-30mins (Est. full charge not accurate)
-Battery sometimes drops by a ridiculous amount E.G. by 20-30% in 1 sec.After checked with Battert Report run in CMDAt Designed Cap at : 45,000,
My Full Charge history as below (Noted that i tried to reset the windows and all previous history is gone so this is what i remember)
First bought (Jan,2018)
Full Charge 2018 : around 40,000 0 44,000
Full Charge 2019(Early months) : Starting to drop to 35,000
Full Chrage as of the last few months : 25,000
Full charge as the last few days of notice: Swings from 22,000 to 9,000 life cycles at 383
Now i cant use it outside without charger. This is very frustating while working**.**
As my device is out of warranty, after searching online, the onl way is replacement at 500USD which seems ridiculus to me just because of battery. I bought this expensive device for the reason of long-term use. this is just a year and a half. Shouldn't it last for 4-5 years for its price?
If you have the same issues and any solutions/suggestions, feel free to share and discuss.
**Update 1 8/19/19:**I can't turn on. I lost my files those i didn't back up. I don't have any other computer to use.
Update 2 8/22/19: I just bought a new PC just to work. I cant wait for 1-2 weeks (Send to another country as there's no microsoft HQ in Thailand) and spend 500USD for just battery replacement.
I kinda gave up and thought it was my fault back then. Now, if you have the same problems. Please up vote.
Update 3 9/1/19:
Seems like my battery is completely dead after testing at a computer shop.
Conclusion:
I am not a hardcore user. In less than 400 cycles, battery (all 4 cells) is dead.
The battery life of my surface pro lasted less than 2 years.
That means you have to pay 500 USD every 2 years. (Could have used this money to upgrade lol)
Maybe 2 in 1 tablets/laptops are not ready for practical use.
Maybe other brands are geting better.
Why do we have to refurbish/replace the device for just a battery which shouldn't cost more than 50 USD.
P.S.
For those who cant even turn the device on,
It's either the circuit is broken duee to defect/unfunctional battary
OR
The battery is completely dead
Worst case = both.
2019-08-22T23:24:52+00:00 -
2019-08-22T17:37:58+00:00 there are companies that can change the battery or try a batpower power bank depending on the size you purchase they can charge a surface up to 2 times
Barb Bowman 80,805 Reputation points MVP Volunteer Moderator2019-08-22T17:26:56+00:00 Please upload the complete battery report html file to OneDrive and share a link
here. Also, please use the Feedback Hub App to file a problem report and share a
link to that report in a reply here.
Barb Bowman 80,805 Reputation points MVP Volunteer Moderator2019-08-22T17:25:15+00:00 they are looking for feedback reports. here is how to get the link so that you
can copy and paste it into a reply here
https://www.tenforums.com/tutorials/130174-share-feedback-feedback-hub-windows-10-a.html
to be honest, *I* don't know what to think of the sudden flurry of reports on
this issue that started after the recent firmware updates. there is clearly a
trend *here in the forum*. but there do not seem to be a lot of feedback hub
reports.
2019-08-22T15:12:04+00:00 Excellent point. I've done all I could to resolve and have come to conclusion that short of spending good money after bad, I now own a proverbial brick; albeit a slim and lightweight version, but useless nonetheless.
Back to point. I also use a 4th generation unit, so I'm anxious to hear from anyone who might have experienced similar issues with the 4th gen model.
