Thank you very much for your time on this.
I'll try this tomorrow and let you know how it all goes - crosses fingers :)
Thanks again
All the best,Steven
I have read many posts and made many attempts to correct this problem without any success.
I was traveling for 3 months and when I returned the battery was completely dead.
Also, each night since my return, the battery drains as much as 12% overnight while shutdown.
I have all MS updates but the problem continues.
Please advise.
THX! :)
Thanks again
All the best,Steven
So I factory reset my Pro4 and did the generic Windows update and it started to charge
Can you try the downloadable recovery image and see if the issue re-occurs?
Go to https://support.microsoft.com/en-us/surfacerecoveryimage (with a different Windows computer if yours is not working properly) and download a recovery image for your Surface. You will need a 16GB USB stick formatted FAT32 (use a Windows computer). Use FULL format and not quick format and give the volume a name like surfboot.. There are full instructions and a
video at
but below are quick instructions). Unzip/extract the recovery zip to the formatted USB stick and then-
To reset your Surface from a USB recovery drive:
Step 1: Make sure your Surface is turned off and plugged in (hold down the power
button for 30 seconds).
Step 2: Insert the USB recovery drive into the USB port on your Surface.
Step 3: Press and hold the volume-down button while you press and release the
power button on your Surface.
Step 4: When the Surface logo appears, release the volume button.
Step 5: When prompted, select the language and keyboard layout you want.
Step 6: Select Troubleshoot > Reset your PC.
If prompted for a recovery key, select Skip this drive at the bottom of the
screen.
Step 7: Select the target operating system you wish to reset. This
refers to the current operating system installed on your Surface.
Step 8: Select Yes, repartition the drives, and on the next page, select Next.
Step 9: Choose Just remove my files.
Step 10: Select Reset.
Surface restarts and the Surface logo displays while the reset process continues
(this can take a while).
Hello Karen and thanks for your note.
As can be seen, by this and quite a number of other related thread, there are quite a number of Surface Pro 4 users experiencing this problem. To date, there has been quite a lot of fault finding, tracking of power loss, and advice including ensuring updates are installed and settings checked - all over a period exceeding one year. All of this effort has failed to resolve the issue; power loss whilst switched off and disconnected from AC persists.
I would be surprised if this issue was not one of the following:
It does not serve the community well to continue telling us to update our laptops. Instead, I (and I assume others) would value an MS representative ensuring that this matter was escalated to both Surface and Windows teams and that you keep us in the loop as to progress on its resolution.
As this issue Surface Pro 4 results in the platform being unable to perform in accordance with specifications and realistic expectations of the purchaser, the breadth of users experiencing the issue, and the time since this issue was first raised, I would think that the matter would receive the highest priority.
If your engineering team would like to investigate this issue using my Surface Pro please reach out. I would happily make it available as part of a concerted effort to resolve the matter.
Sincerley
Tim
Hello Tim923347 and LoriEvans1,
Thank you for reaching out Surface Community. We sincerely apologize for the misinformation by Lloyd. This is not a known issue for Surface Pro 4 Devices. There are several reasons why this is happening. It could be that there are pending updates on your Surface that were not installed. It could be that the drivers on your Surface are not updated that is why it won't work properly.
Please follow the steps below:
Please keep us posted.
Karen
I am just starting to have this problem as well. It is very frustrating. I didn't realize that this is an ongoing problem. When I inquired, they will replace the device (the whole surface) for 450! Okay, compared to what it cost, that's great. But, this is a problem that seems to happen right out of warranty...
I think they need to replace the charger or the batteries for FREE - it seems to me that this should fall under the "recall" law of cars...
Is this just another way that the tech giants are not being regulated and so they don't care...
I need to make some phone calls about this... I've barley used this computer until the last year regardless of the time that I've actually owned it...
Not good on this one , Microsoft.
One, not happy, customer.
