Surface Pro 3 - Missing Surface Pro Touch Controller Firmware after reimage
2014-06-26T13:57:29+00:00
MDT 2013 - Windows 8.1 all updates.
Download surface Pro 3 firmware and driver http://www.microsoft.com/en-us/download/details.aspx?id=38826 to mdt 2013 out of box driver. Reimaged it, but missing only one and most essential driver
UEFI\RES_{e5fff56f-d160-4365-9e21-22b06f6746dd}&REV_0
without this driver, surface pro is just untouchable...can anyone help me to find this driver.
thanks in advance...
2014-06-27T23:39:57+00:00
Hello Orionbelt,
I'm sorry that you are experiencing the inconvenience of this missing driver on your Surface Pro 3. We're here to help.
As this is a pretty technical issue related to a re-image of the device, we suggest you contact our Technical Support Team to help you with this in real-time. You can contact them through chat or phone here.
Thanks for reaching out to us, and please contact us again if you have any other questions.
Best Wishes,
Zack_T
126 additional answers
    2014-12-08T12:40:25+00:00
    I have strong suspicion that this is somehow related to only hardware id REV_1A31A36.  If you open up the touch firmware installation INF, there is not an entry for this hardware ID and thus I believe why the installation is failing.  I like to hear from anyone who has success with firmware 426.27.66.0 on this hardware ID.
    I'm on my second surface with touch controller firmware hardware id REV_1A31A36... Have tried the suggested solutions provided in the thread and from Microsoft support multiple times without success.
    @ccote, good to hear you've resolved the issue - can you confirm the hardware id of your touch controller firmware?
    Aidan.
    Hi, the touch controller firmware version oils 426.27.66.0. The driver provider is N-Trig. Hardware Id is REV_1AA1B42.
    Let me know if you have other questions,
    Ccote
    2014-12-07T14:50:39+00:00
    Aidan.
    2014-12-07T14:20:10+00:00
    Well, I have finally been able to install the firmware by running all updates (including a windows update that takes something like 700-800 mb) before. Then, with my surface being in the docking station (not sure if it was necessary though), I restarted my it and the firmware update finally succeeded.
    2014-12-07T13:43:29+00:00
    I have the same problem, and tried reinstalling with it at 100% and no keyboard, but I still have the "yellow triangle" and failed "firmware" note in the update list.
    I have had this less than a month, and although it seems to be working I am worried that this was a firmware update it is important that it should be on my surface pro i7
    John
