2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-30T07:04:35+00:00
    Greg...Any updates on the battery life issue?
    2016-07-30T03:18:30+00:00
    Hello everyone,
    We are aware of some customers reporting a scenario with their Surface Pro 3 batteries in which the system is reporting lower battery capacity than expected. We’ve isolated this to a limited number of customers experiencing this issue.
    Based on our investigations we can confirm that it is not an issue with the battery cells, and we believe this is something that can be addressed via software.
    We’re working through the details of how we deliver that.
    Thank you all for the details you've shared here,
    Greg
    Hi Greg,
    Earlier as I reported to you, the battery status was Plugged In Not Charging (85%).
    Today I switched it on with AC power, no battery is detected.
    The battery report cannot find the battery.
    Take a look at the screenshot.
    Please do something.
    I with my slate  are stuck to the AC power supply.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=e545a498-5c2e-4eca-951c-f4b415fb8284)
    2016-07-29T21:42:23+00:00
    I am having the same exact issue with my surface pro 3. Hopefully MSFT can come up with a software update. Right now my surface has become almost unusable. As soon the power cord is off, my surface shuts down.
    Battery capacity history
    Charge capacity history of the system's batteries
    2015-11-16 - 2015-11-22 39,694 mWh 42,157 mWh
    2015-11-22 - 2015-11-29 39,492 mWh 42,157 mWh
    2015-11-29 - 2015-12-23 39,477 mWh 42,157 mWh
    2015-12-23 - 2015-12-30 41,936 mWh 42,157 mWh
    2015-12-30 - 2016-01-03 40,794 mWh 42,157 mWh
    2016-01-03 - 2016-01-12 38,920 mWh 42,157 mWh
    2016-01-12 - 2016-01-17 41,025 mWh 42,157 mWh
    2016-01-17 - 2016-01-25 42,376 mWh 42,157 mWh
    2016-01-25 - 2016-01-31 41,085 mWh 42,157 mWh
    2016-01-31 - 2016-02-07 36,826 mWh 42,157 mWh
    2016-02-07 - 2016-02-14 33,818 mWh 42,157 mWh
    2016-02-14 - 2016-02-21 29,770 mWh 42,157 mWh
    2016-02-21 - 2016-02-29 25,827 mWh 42,157 mWh
    2016-02-29 - 2016-03-06 24,191 mWh 42,157 mWh
    2016-03-06 - 2016-03-13 24,899 mWh 42,157 mWh
    2016-03-13 - 2016-03-20 22,811 mWh 42,157 mWh
    2016-03-20 - 2016-03-27 20,615 mWh 42,157 mWh
    2016-03-27 - 2016-04-03 19,736 mWh 42,157 mWh
    2016-04-03 - 2016-04-10 15,129 mWh 42,157 mWh
    2016-04-10 - 2016-04-18 13,426 mWh 42,157 mWh
    2016-04-18 - 2016-04-25 12,821 mWh 42,157 mWh
    2016-04-25 - 2016-05-02 12,468 mWh 42,157 mWh
    2016-05-02 - 2016-05-09 11,467 mWh 42,157 mWh
    2016-05-09 - 2016-05-16 10,215 mWh 42,157 mWh
    2016-05-16 - 2016-05-23 8,848 mWh 42,157 mWh
    2016-05-23 - 2016-05-30 7,468 mWh 42,157 mWh
    2016-05-30 - 2016-06-06 6,047 mWh 42,157 mWh
    2016-06-07 5,713 mWh 42,157 mWh
    2016-06-08 5,455 mWh 42,157 mWh
    2016-06-09 5,191 mWh 42,157 mWh
    2016-06-10 5,191 mWh 42,157 mWh
    2016-06-11 5,090 mWh 42,157 mWh
    2016-06-12 4,932 mWh 42,157 mWh
    2016-06-13 4,932 mWh 42,157 mWh
    2016-06-14 4,932 mWh 42,157 mWh
    2016-07-29T19:41:56+00:00
    I just spoke with a support person. He mentioned that they are aware of the issue and working on a software solution. He said that these solutions normally take 2 - 3 months to develop. I'd love if it would come faster, but I have a feeling that he is right.
