2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-28T19:19:00+00:00
    I'm not entirely sure this is just a SIMPLO issue - my battery is the LG:
    Installed batteries
    NAME X883815
    MANUFACTURER LGC-LGC
    SERIAL NUMBER 1149835268
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 26,798 mWh
    CYCLE COUNT 134
    But since March it has diminished in capacity:
    2016-01-04 - 2016-01-11 44,270 mWh 42,157 mWh
    2016-01-11 - 2016-01-18 44,270 mWh 42,157 mWh
    2016-01-18 - 2016-01-25 44,257 mWh 42,157 mWh
    2016-01-25 - 2016-02-01 44,270 mWh 42,157 mWh
    2016-02-01 - 2016-02-08 44,198 mWh 42,157 mWh
    2016-02-08 - 2016-02-22 44,255 mWh 42,157 mWh
    2016-02-22 - 2016-02-29 44,235 mWh 42,157 mWh
    2016-02-29 - 2016-03-07 44,131 mWh 42,157 mWh
    2016-03-07 - 2016-03-14 43,153 mWh 42,157 mWh
    2016-03-14 - 2016-03-21 41,971 mWh 42,157 mWh
    2016-03-21 - 2016-03-28 40,988 mWh 42,157 mWh
    2016-03-28 - 2016-04-05 40,010 mWh 42,157 mWh
    2016-04-05 - 2016-04-11 39,342 mWh 42,157 mWh
    2016-04-11 - 2016-04-18 38,691 mWh 42,157 mWh
    2016-04-18 - 2016-04-25 38,092 mWh 42,157 mWh
    2016-04-25 - 2016-05-02 37,565 mWh 42,157 mWh
    2016-05-02 - 2016-05-09 36,199 mWh 42,157 mWh
    2016-05-09 - 2016-05-18 35,512 mWh 42,157 mWh
    2016-05-18 - 2016-05-23 35,207 mWh 42,157 mWh
    2016-05-23 - 2016-05-30 33,536 mWh 42,157 mWh
    2016-05-30 - 2016-06-06 32,956 mWh 42,157 mWh
    2016-06-06 - 2016-06-13 32,468 mWh 42,157 mWh
    2016-06-13 - 2016-06-20 31,609 mWh 42,157 mWh
    2016-06-20 - 2016-06-27 30,860 mWh 42,157 mWh
    2016-06-27 - 2016-07-04 30,045 mWh 42,157 mWh
    2016-07-04 - 2016-07-11 29,042 mWh 42,157 mWh
    2016-07-11 - 2016-07-18 28,350 mWh 42,157 mWh
    2016-07-19 28,006 mWh 42,157 mWh
    2016-07-20 28,006 mWh 42,157 mWh
    2016-07-21 28,006 mWh 42,157 mWh
    2016-07-22 28,006 mWh 42,157 mWh
    2016-07-23 28,006 mWh 42,157 mWh
    2016-07-24 27,860 mWh 42,157 mWh
    2016-07-25 26,798 mWh 42,157 mWh
    2016-07-26 26,798 mWh 42,157 mWh
    2016-07-27 26,798 mWh 42,157 mWh
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=e13a5984-48ce-4d1d-b4d6-25bb60b780c8)
    Estimated time on battery is less than 2 hors now.  It used to be about 7
    2016-07-28T19:13:30+00:00
    I had this occur to my SP3 in April of this year well before there was any acknowledgement of the problem. I paid $450 for a replacement device, as I was approximately 45 days out of warranty and in fact everyone I dealt with at Microsoft was quite rude about the fact I was having a problem like this and being asked to shell out a great deal of the value of the device for a replacement after such a short time. Not to mention the fact that we were originally promised battery replacements for $200.
    Will Microsoft be reimbursing me for this cost now that they acknowledge this is a widespread issue? At this point all plans to roll out Surfaces more widely in my workplace have been shelved because of this issue and the treatment we received in dealing with it.
    2016-07-28T17:33:06+00:00
    Till yesterday my SP3 kept going into sleep mode every 10 or so minutes irrespective of the power settings. This was in addition to the horrible battery life measurable in minutes. There was an update last night. Since today morning, the SP3 is atleast not going into sleep mode. Fingers crossed.
    If I top the battery to 100% and remove the power cable, the power drops from 100 to 1 in just a few seconds, it'd be called comical if it wasn't my daily driver machine... Not sure if I can post a video here of that happening, will try to do that.
    2016-07-28T17:28:50+00:00
    That article is doing nothing more than quoting the MS answer on the first page of this thread.
    I also have SIMPLO battery and out of warranty. Luckily my battery is around 95% capacity.
    I seriously doubt this is a software issue.
