2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-20T07:48:19+00:00
    I'm still holding out hope that this might be firmware related, after all this has happened to Surface Pro 2 devices in the past:
    http://news.softpedia.com/news/How-to-Fix-Surface-Pro-2-Plugged-In-Not-Charging-Error-412945.shtml
    I remember this because my wife has a Surface Pro 2 and it wouldn't charge after installing the December firmware so had to be permanently plugged in to use.  If the Surface Pro 3 firmware is preventing the device from charging but the system thinks it is charging then it might register as reduced capacity.
    The status of my battery is currently "97% available (plugged in, not charging) and it always seems to do that around the 95% mark.
    I know, glass half full view of the situation...
    2016-07-20T05:50:07+00:00
    Add me to the list. Simplo battery full charge capacity less than 50% of original after just over 1 year.
    Yes I expect battery degradation but not to this extent!
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 19,608 mWh
    CYCLE COUNT 182
     That's not many cycles for >50% degradation!
    2016-07-20T03:42:53+00:00
    I had the same experience, no charge for the call to customer service, but $450 for a replacement.  Still, I'd recommend calling, might not be a bad idea to get a case number and give Microsoft an idea of the number of people that are experiencing the same problem.  Really wish I had gotten one of the LGC batteries - those seem to be pretty solid.
    2016-07-20T03:00:24+00:00
    I haven't been able to boot up for a week now. I have to resort to buying a new laptop ( a HP btw...sick of this SP3 battery issue). I think if we were sold a defective part, Microsoft should own up to it instead of asking us to pay for the repairs.
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1163074052
    CHEMISTRY LION
    FULL CHARGE CAPACITY 1,254 mWh
    CYCLE COUNT 127
    Recent usage
    Power states over the last 3 days
    2016-07-1423:08:47 Active AC 2 % 23 mWh
    23:30:00 Report generated AC 73 % 912 mWh
    Battery usage
    Battery drains over the last 3 days
    Usage history
    History of system usage on AC and battery
    2015-12-06 - 2015-12-13 1:01:57 11:17:33 148:42:57 2:06:21
    2015-12-13 - 2015-12-20 7:20:57 6:29:41 143:18:53 8:38:57
    2015-12-20 - 2015-12-27 2:24:08 4:42:42 154:59:25 0:00:43
    2015-12-27 - 2016-01-03 0:57:29 10:14:07 156:26:27 0:00:05
    2016-01-03 - 2016-01-10 0:51:07 1:15:39 165:41:13 -
    2016-01-10 - 2016-01-17 1:58:24 14:54:43 156:52:43 0:07:13
    2016-01-17 - 2016-01-24 1:28:28 11:58:30 152:50:16 0:02:41
    2016-01-24 - 2016-01-31 0:06:38 - 165:43:02 0:32:48
    2016-01-31 - 2016-02-07 0:54:57 4:12:21 164:08:27 -
    2016-02-07 - 2016-02-14 0:00:26 - 167:56:27 -
    2016-02-14 - 2016-02-21 0:00:35 - 166:35:24 -
    2016-02-21 - 2016-02-28 0:02:11 - 166:48:53 -
    2016-02-28 - 2016-03-06 0:08:59 - 141:57:45 24:47:44
    2016-03-06 - 2016-03-13 2:47:47 1:08:20 271:06:49 54:26:22
    2016-03-13 - 2016-03-20 0:02:51 - 147:35:02 19:12:47
    2016-03-20 - 2016-03-27 2:40:08 60:22:42 82:22:58 22:04:40
    2016-03-27 - 2016-04-03 0:38:27 12:26:08 120:30:57 33:37:26
    2016-04-03 - 2016-04-10 1:34:31 12:21:09 115:34:05 30:16:14
    2016-04-10 - 2016-04-17 1:40:56 12:21:09 152:27:47 162:46:28
    2016-04-17 - 2016-04-24 1:41:45 12:21:09 185:40:53 296:32:39
    2016-04-24 - 2016-05-01 0:50:00 1:50:04 41:15:16 123:50:00
    2016-05-01 - 2016-05-08 0:56:04 0:00:08 15:13:22 45:59:58
    2016-05-08 - 2016-05-15 1:18:19 14:38:01 46:11:23 98:03:02
    2016-05-15 - 2016-05-22 2:21:22 26:02:46 38:02:04 101:14:58
    2016-05-22 - 2016-05-29 0:00:51 0:00:02 46:51:24 121:05:27
    2016-05-29 - 2016-06-05 0:00:40 - 33:49:49 133:06:08
    2016-06-05 - 2016-06-12 0:01:58 - 45:39:45 122:15:44
    2016-06-12 - 2016-06-19 1:21:07 - 31:33:05 134:41:16
    2016-06-19 - 2016-06-26 0:13:51 0:00:24 39:20:52 124:37:34
    2016-06-26 - 2016-07-03 0:00:15 0:00:14 29:15:19 96:55:32
    2016-07-04 - - - -
    2016-07-05 - - - -
    2016-07-06 - - - -
    2016-07-07 - - - -
    2016-07-08 - - - -
    2016-07-09 - - - -
    2016-07-10 - - - -
    2016-07-11 - - - -
    2016-07-12 - - - -
    2016-07-13 - - - -
    Battery capacity history
    Charge capacity history of the system's batteries
    2015-12-06 - 2015-12-13 41,098 mWh 42,157 mWh
    2015-12-13 - 2015-12-20 41,199 mWh 42,157 mWh
    2015-12-20 - 2015-12-27 40,858 mWh 42,157 mWh
    2015-12-27 - 2016-01-03 40,855 mWh 42,157 mWh
    2016-01-03 - 2016-01-10 40,782 mWh 42,157 mWh
    2016-01-10 - 2016-01-17 40,773 mWh 42,157 mWh
    2016-01-17 - 2016-01-24 40,766 mWh 42,157 mWh
    2016-01-24 - 2016-01-31 40,854 mWh 42,157 mWh
    2016-01-31 - 2016-02-07 40,858 mWh 42,157 mWh
    2016-02-07 - 2016-02-14 40,694 mWh 42,157 mWh
    2016-02-14 - 2016-02-21 40,668 mWh 42,157 mWh
    2016-02-21 - 2016-02-28 40,668 mWh 42,157 mWh
    2016-02-28 - 2016-03-06 40,687 mWh 42,157 mWh
    2016-03-06 - 2016-03-13 40,704 mWh 42,157 mWh
    2016-03-13 - 2016-03-20 40,531 mWh 42,157 mWh
    2016-03-20 - 2016-03-27 41,392 mWh 42,157 mWh
    2016-03-27 - 2016-04-03 42,552 mWh 42,157 mWh
    2016-04-03 - 2016-04-10 42,556 mWh 42,157 mWh
    2016-04-10 - 2016-04-17 42,166 mWh 42,157 mWh
    2016-04-17 - 2016-04-24 41,088 mWh 42,157 mWh
    2016-04-24 - 2016-05-01 36,875 mWh 42,157 mWh
    2016-05-01 - 2016-05-08 29,389 mWh 42,157 mWh
    2016-05-08 - 2016-05-15 28,510 mWh 42,157 mWh
    2016-05-15 - 2016-05-22 22,849 mWh 42,157 mWh
    2016-05-22 - 2016-05-29 22,473 mWh 42,157 mWh
    2016-05-29 - 2016-06-05 16,609 mWh 42,157 mWh
    2016-06-05 - 2016-06-12 16,378 mWh 42,157 mWh
    2016-06-12 - 2016-06-19 8,445 mWh 42,157 mWh
    2016-06-19 - 2016-06-26 7,881 mWh 42,157 mWh
    2016-06-26 - 2016-07-03 7,881 mWh 42,157 mWh
    2016-07-04 7,881 mWh 42,157 mWh
    2016-07-05 7,881 mWh 42,157 mWh
    2016-07-06 7,881 mWh 42,157 mWh
    2016-07-07 7,881 mWh 42,157 mWh
    2016-07-08 7,881 mWh 42,157 mWh
    2016-07-09 7,881 mWh 42,157 mWh
    2016-07-10 7,881 mWh 42,157 mWh
    2016-07-11 7,881 mWh 42,157 mWh
    2016-07-12 7,881 mWh 42,157 mWh
    2016-07-13 7,881 mWh 42,157 mWh
