2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-10-28T10:32:30+00:00
    Microsoft just is not responding any more on SP3 battery issues. Sorry.
    2016-10-28T06:21:28+00:00
    Dear Barb,
    I just got this weird problem again. I lose 65% in 2 hours with Wifi, web browsing and Outlook email printing. (In Battery Saving mode.)
    I think I need new 2016 Microsoft Surfa
    ce Book badly that my Surface Pro 3 just refuse to work with me anymore.
    Battery report
    COMPUTER NAME SURFACEPRO3
    SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
    BIOS 3.11.1550 06/30/2016
    OS BUILD 14393.321.amd64fre.rs1_release_inmarket.161004-2338
    PLATFORM ROLE Slate
    CONNECTED STANDBY Supported
    REPORT TIME 2016-10-28 12:36:31
    Installed batteries
    Information about each currently installed battery
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1181752836
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 38,889 mWh
    CYCLE COUNT 263
    Recent usage
    Power states over the last 3 days
    2016-10-25 13:33:34 Connected standby Battery 67 % 26,106 mWh
    13:33:34 Active Battery 67 % 26,106 mWh
    13:46:53 Connected standby Battery 63 % 24,495 mWh
    14:16:53 Suspended 63 % 24,396 mWh
    15:23:03 Connected standby Battery 62 % 24,198 mWh
    15:23:03 Active Battery 62 % 24,198 mWh
    15:25:04 Connected standby Battery 61 % 23,925 mWh
    15:44:02 Active Battery 61 % 23,803 mWh
    15:49:50 Connected standby Battery 59 % 23,112 mWh
    16:19:50 Suspended 59 % 23,013 mWh
    2016-10-26 08:02:37 Connected standby Battery 100 % 38,403 mWh
    08:02:37 Active Battery 100 % 38,403 mWh
    08:20:57 Connected standby Battery 100 % 38,403 mWh
    08:26:23 Active Battery 100 % 38,403 mWh
    08:32:59 Connected standby Battery 94 % 35,978 mWh
    08:33:08 Active Battery 94 % 35,963 mWh
    08:57:44 Connected standby Battery 89 % 34,299 mWh
    09:02:24 Active Battery 89 % 34,261 mWh
    09:06:36 Connected standby Battery 89 % 33,995 mWh
    09:07:20 Active Battery 88 % 33,972 mWh
    09:17:44 Connected standby Battery 87 % 33,250 mWh
    11:30:00 Suspended 86 % 32,931 mWh
    11:50:49 Connected standby Battery 85 % 32,718 mWh
    11:50:49 Active Battery 85 % 32,718 mWh
    12:47:24 Connected standby Battery 66 % 25,528 mWh
    13:17:23 Suspended 66 % 25,430 mWh
    17:16:19 Connected standby Battery 66 % 25,217 mWh
    17:16:19 Active Battery 66 % 25,217 mWh
    17:31:13 Connected standby Battery 61 % 23,279 mWh
    17:41:08 Active Battery 60 % 23,203 mWh
    17:51:29 Connected standby Battery 58 % 22,124 mWh
    17:52:31 Active Battery 58 % 22,108 mWh
    18:36:46 Connected standby Battery 44 % 17,032 mWh
    18:48:20 Active Battery 44 % 16,971 mWh
    19:34:49 Connected standby Battery 31 % 11,719 mWh
    20:04:48 Suspended 30 % 11,605 mWh
    2016-10-27 00:16:15 Connected standby Battery 30 % 11,529 mWh
    00:16:15 Connected standby AC 30 % 11,529 mWh
    00:16:15 Active AC 30 % 11,529 mWh
    01:07:39 Suspended 74 % 28,310 mWh
    01:09:24 Active AC 75 % 28,622 mWh
    01:34:42 Connected standby AC 84 % 32,323 mWh
    01:35:44 Active AC 85 % 32,589 mWh
    07:31:13 Active Battery 101 % 38,692 mWh
    07:35:27 Connected standby Battery 101 % 38,692 mWh
    08:35:24 Active Battery 100 % 38,692 mWh
    09:22:38 Connected standby Battery 88 % 33,987 mWh
    09:51:24 Active Battery 88 % 33,896 mWh
    10:29:18 Connected standby Battery 75 % 28,926 mWh
    10:44:01 Active Battery 75 % 28,857 mWh
    12:12:47 Connected standby Battery 48 % 18,688 mWh
    12:42:45 Suspended 48 % 18,643 mWh
    2016-10-28 08:51:36 Connected standby Battery 100 % 38,889 mWh
    08:51:36 Active Battery 100 % 38,889 mWh
    09:36:31 Connected standby Battery 87 % 33,744 mWh
    09:50:53 Active Battery 87 % 33,676 mWh
    09:58:26 Connected standby Battery 85 % 32,946 mWh
    10:01:55 Active Battery 85 % 32,908 mWh
    10:24:04 Connected standby Battery 77 % 29,777 mWh
    10:26:38 Active Battery 76 % 29,739 mWh
    10:30:39 Connected standby Battery 76 % 29,412 mWh
    10:31:54 Active Battery 75 % 29,359 mWh
    12:36:00 Report generated Battery 11 % 4,210 mWh
    Battery usage
    Battery drains over the last 3 days
    2016-10-25 13:33:34 Connected standby 0:00:00 - -
    13:33:34 Active 0:13:19 4 % 1,611 mWh
    13:46:53 Connected standby 0:29:59 - 99 mWh
    15:23:03 Connected standby 0:00:00 - -
    15:23:03 Active 0:02:00 1 % 273 mWh
    15:25:04 Connected standby 0:18:57 - 122 mWh
    15:44:02 Active 0:05:47 2 % 691 mWh
    15:49:50 Connected standby 0:30:00 - 99 mWh
    2016-10-26 08:02:37 Connected standby 0:00:00 - -
    08:02:37 Active 0:18:20 - -
    08:20:57 Connected standby 0:05:25 - -
    08:26:23 Active 0:06:36 6 % 2,425 mWh
    08:32:59 Connected standby 0:00:08 - 15 mWh
    08:33:08 Active 0:24:36 4 % 1,664 mWh
    08:57:44 Connected standby 0:04:40 - 38 mWh
    09:02:24 Active 0:04:12 1 % 266 mWh
    09:06:36 Connected standby 0:00:44 - 23 mWh
    09:07:20 Active 0:10:23 2 % 722 mWh
    09:17:44 Connected standby 2:12:16 1 % 319 mWh
    11:50:49 Connected standby 0:00:00 - -
    11:50:49 Active 0:56:35 19 % 7,190 mWh
    12:47:24 Connected standby 0:29:59 - 98 mWh
    17:16:19 Connected standby 0:00:00 - -
    17:16:19 Active 0:14:54 5 % 1,938 mWh
    17:31:13 Connected standby 0:09:54 - 76 mWh
    17:41:08 Active 0:10:21 3 % 1,079 mWh
    17:51:29 Connected standby 0:01:02 - 16 mWh
    17:52:31 Active 0:44:14 13 % 5,076 mWh
    18:36:46 Connected standby 0:11:34 - 61 mWh
    18:48:20 Active 0:46:28 14 % 5,252 mWh
    19:34:49 Connected standby 0:29:59 - 114 mWh
    2016-10-27 00:16:15 Connected standby 0:00:00 - -
    07:31:13 Active 0:04:14 - -
    07:35:27 Connected standby 0:59:56 - -
    08:35:24 Active 0:47:14 12 % 4,705 mWh
    09:22:38 Connected standby 0:28:45 - 91 mWh
    09:51:24 Active 0:37:53 13 % 4,970 mWh
    10:29:18 Connected standby 0:14:42 - 69 mWh
    10:44:01 Active 1:28:46 26 % 10,169 mWh
    12:12:47 Connected standby 0:29:58 - 45 mWh
    2016-10-28 08:51:36 Connected standby 0:00:00 - -
    08:51:36 Active 0:44:55 13 % 5,145 mWh
    09:36:31 Connected standby 0:14:21 - 68 mWh
    09:50:53 Active 0:07:33 2 % 730 mWh
    09:58:26 Connected standby 0:03:28 - 38 mWh
    10:01:55 Active 0:22:08 8 % 3,131 mWh
    10:24:04 Connected standby 0:02:33 - 38 mWh
    10:26:38 Active 0:04:01 1 % 327 mWh
    10:30:39 Connected standby 0:01:14 - 53 mWh
    10:31:54 Active 2:04:05 65 % 25,149 mWh
    PERIOD
    2016-08-08 - 2016-08-15 3:24:17 33:29:19 10:37:39 14:17:53
    2016-08-15 - 2016-08-22 5:33:47 9:42:38 1:28:38 0:15:00
    2016-08-22 - 2016-08-29 5:21:20 8:53:20 3:06:38 -
    2016-08-29 - 2016-09-05 6:15:25 31:49:23 30:03:15 12:37:50
    2016-09-05 - 2016-09-12 4:05:21 6:31:34 21:36:38 19:02:18
    2016-09-12 - 2016-09-19 15:38:20 4:40:35 51:27:46 5:32:03
    2016-09-19 - 2016-09-26 13:22:39 5:53:14 64:05:55 8:29:45
    2016-09-26 - 2016-10-03 13:05:39 20:10:55 21:37:32 4:31:03
    2016-10-03 - 2016-10-10 12:19:09 16:14:12 43:26:10 40:00:46
    2016-10-10 - 2016-10-17 10:55:55 7:53:59 41:54:16 8:33:07
    2016-10-17 2:05:24 3:11:38 8:10:34 0:04:45
    2016-10-18 2:14:26 0:47:38 7:30:07 -
    2016-10-19 3:47:35 0:30:14 5:35:12 0:14:58
    2016-10-20 0:33:08 7:53:59 7:30:50 -
    2016-10-21 - - - -
    2016-10-22 - - 22:56:22 1:00:55
    2016-10-23 - - 23:59:38 -
    2016-10-24 0:00:10 - 23:27:01 0:26:02
    2016-10-25 2:08:42 2:10:18 8:07:53 -
    2016-10-26 3:56:36 3:45:37 - -
    2016-10-27 2:58:03 2:13:19 6:20:41 0:52:23
    PERIOD
    2016-08-08 - 2016-08-15 26,876 mWh 42,157 mWh
    2016-08-15 - 2016-08-22 24,303 mWh 42,157 mWh
    2016-08-22 - 2016-08-29 22,855 mWh 42,157 mWh
    2016-08-29 - 2016-09-05 34,324 mWh 42,157 mWh
    2016-09-05 - 2016-09-12 38,649 mWh 42,157 mWh
    2016-09-12 - 2016-09-19 38,484 mWh 42,157 mWh
    2016-09-19 - 2016-09-26 38,427 mWh 42,157 mWh
    2016-09-26 - 2016-10-03 38,602 mWh 42,157 mWh
    2016-10-03 - 2016-10-10 38,405 mWh 42,157 mWh
    2016-10-10 - 2016-10-17 38,493 mWh 42,157 mWh
    2016-10-17 38,938 mWh 42,157 mWh
    2016-10-18 38,819 mWh 42,157 mWh
    2016-10-19 38,463 mWh 42,157 mWh
    2016-10-20 38,630 mWh 42,157 mWh
    2016-10-21 39,186 mWh 42,157 mWh
    2016-10-22 38,912 mWh 42,157 mWh
    2016-10-23 38,912 mWh 42,157 mWh
    2016-10-24 38,912 mWh 42,157 mWh
    2016-10-25 38,912 mWh 42,157 mWh
    2016-10-26 38,573 mWh 42,157 mWh
    2016-10-27 38,588 mWh 42,157 mWh
    PERIOD
    2016-08-08 - 2016-08-15 3:25:52 417:04:16<br><br>4 % / 16 h 5:22:55 654:12:26<br><br>2 % / 16 h
    2016-08-15 - 2016-08-22 3:35:42 85:08:07<br><br>19 % / 16 h 6:14:10 147:40:46<br><br>11 % / 16 h
    2016-08-22 - 2016-08-29 3:24:41 89:36:51<br><br>18 % / 16 h 6:17:33 165:17:50<br><br>10 % / 16 h
    2016-08-29 - 2016-09-05 2:35:24 315:19:39<br><br>5 % / 16 h 3:10:52 387:17:15<br><br>4 % / 16 h
    2016-09-05 - 2016-09-12 6:21:25 356:45:27<br><br>4 % / 16 h 6:56:02 389:08:20<br><br>4 % / 16 h
    2016-09-12 - 2016-09-19 4:18:33 102:43:13<br><br>16 % / 16 h 4:43:13 112:31:27<br><br>14 % / 16 h
    2016-09-19 - 2016-09-26 5:34:32 202:42:48<br><br>8 % / 16 h 6:07:00 222:23:25<br><br>7 % / 16 h
    2016-09-26 - 2016-10-03 3:46:26 222:08:42<br><br>7 % / 16 h 4:07:17 242:36:12<br><br>7 % / 16 h
    2016-10-03 - 2016-10-10 5:23:50 180:16:27<br><br>9 % / 16 h 5:55:28 197:53:11<br><br>8 % / 16 h
    2016-10-10 - 2016-10-17 5:17:36 202:11:00<br><br>8 % / 16 h 5:47:50 221:25:42<br><br>7 % / 16 h
    2016-10-17 4:54:50 195:32:25<br><br>8 % / 16 h 5:19:12 211:42:20<br><br>8 % / 16 h
    2016-10-18 6:06:46 1027:15:56<br><br>2 % / 16 h 6:38:19 1115:35:56<br><br>1 % / 16 h
    2016-10-19 6:25:21 140:26:33<br><br>11 % / 16 h 7:02:22 153:55:50<br><br>10 % / 16 h
    2016-10-20 6:08:26 6781:28:21<br><br>- / 16 h 6:42:04 7400:38:07<br><br>- / 16 h
    2016-10-21 - - - -
    2016-10-22 - - - -
    2016-10-23 - - - -
    2016-10-24 - - - -
    2016-10-25 5:32:30 205:06:23<br><br>8 % / 16 h 6:00:14 222:12:39<br><br>7 % / 16 h
    2016-10-26 5:56:19 190:50:56<br><br>8 % / 16 h 6:29:26 208:34:53<br><br>8 % / 16 h
    2016-10-27 5:46:13 418:14:44<br><br>4 % / 16 h 6:18:15 456:55:45<br><br>4 % / 16 h
    Anyway, just report that the problem is still present.
    Thank you,
    Nirut Yongsithikorn,
    2016-10-20T08:16:10+00:00
    Dear Barb,
    Thank you for your effort to try answering to as many questions as possible.
    Actually, the August updates already helps a lot but it feels like the battery capacity is not about like before the issue begin.
    Hope they are working on to completely remedies the issues.
    Thank you really much.
    Thank you,
    2016-10-19T21:05:15+00:00
    It's great Barb that we have people like you that volunteer their time but the communication on this is unfortunate.
    I am plagued by the LGC battery issue, and the worst case where is won't work on battery at all and it won't wake from hibernation.
    So my only alternative here is either for me as an owner of an unreliable device to get some answers is to watch forums and blogs as to when an issue is fixed or MS provides an update. I can't just call them up or email them to find out what is happening on this issue...no wait, I can. I can pay $99USD to talk to someone that, from what I'm hearing, will just suggest you get the battery replacement that MS said would be $200USD...no wait, that's no longer available. You have to purchase a refurb for $399USD.
    I have been managing the IT for organizations for 15 years now and have dealt with multiple vendors in my journeys. Hardware vendors have to communicate to ensure brand trust both to consumers and especially to businesses that by in multiples.
    Microsoft's communication strategy is not one setup for long term success as a hardware vendor. It's important for MS to correct this issue, to protect a great product through better communication before they destroy yet another product; it's time for Panos Panay to be replaced.
