2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-09-21T00:40:43+00:00
    Simon:
    I have something of a similar problem - i have spoken to 3 or 4 Microsoft techs and been informed that i have a faulty battery that it is a hardware issue - the problem is that a friend of mine purchased this sp3 and the battery issue only began after i purchased it from him- shortly after the firmware upgrade that fixed the Simplo batteries - i have the LGC battery.
    My battery shows the design full charge as 42,(and change), but my machines full charge shows over 44,000 - so the battery is designed to hold something like a 5900 MAH charge, yet it is being over-charged, possibly past 6000MAH.... Even though this issue only just showed up, and even though the device is less than 4 months out of warranty, and even though it's obviously a risk to continue using a lithium ion battery that continuously over charges, and even though the battery has only been through 120 cycle (the device has not been used very much) Microsoft informed me that had it been s few months ago i would have qualified for a free replacement; however, since it's out of warranty, too bad, nothing will be done.
    I'm only posting this to see if anyone else is experiencing anything similar.
    Thanks.
    2016-09-20T04:10:32+00:00
    Sorry to hear that, but I refuse to pay such a high price for a battery replacement.
    So, after almost 4 weeks of speaking to Microsoft Japan support, they finally decided to call me back with the awesome news of suggesting a battery replacement, except the battery replacement is going to cost 78,000 yen, which works out to be about 800 US dollars.
    I declined their offer and have vowed to never again buy another Microsoft product.
    2016-09-19T15:14:44+00:00
    Finally I had to pay $450 + tax to get it repaired from MS :( So Sad.....
    2016-09-19T14:38:44+00:00
    I'm seeing something similar. Starting to feel like this nightmare will never end...  I understand that these batteries degrade over time, especially when they're used plugged in most of the time, but a daily reduction?
    I think the issue is being caused by the fact that the power supply on the dock can't provide enough charge so it is continually falling back on the battery causing very small decreases in charge followed by a recharge once power draw reduces (that is the worst way to use a rechargeable battery). Essentially I'm saying there is a design flaw in the SP3 and the way the battery is used even when on mains power.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=69ea76e2-04ff-4e6a-8647-fc8e89f1f7fe)
