2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-09-12T16:41:27+00:00
    This might be helpful to me, except now my battery is dead and it won't charge.  So I have a brick.  And MS wants $450 to send me a replacement.
    2016-09-11T16:36:26+00:00
    Sorry man, I don't have that. It went through the support email and ticket I raised.
    2016-09-11T09:32:32+00:00
    Thank you for the reply. I was wondering if you could send me their email address to my email address? I don't have a LinkedIn account my email address is DJmizuhara at gmail dot com
    Congratulations on getting a fully functional SP3 without the dodgy battery.
    2016-09-11T08:22:08+00:00
    I'd escalated my issue before the fix. Just search on LinkedIn for MS folks in Japan for marketing, sales and devices and use firstname.lastname@microsoft.com email. Two APAC big shots called me a few days later and offered to replace mine. Although I bought it in Sinagpore, I stay in Thailand now; they shipped the replacement unit here from Bangkok. I am now done with re-loading my stuff and testing the new SP3 (LGC batt) and will return the old one with SIMPLO battery next week. This is the kind of service that should have been default, I suppose. The $800 you're being quoted is absolutely nonsense.
