2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-09-09T07:36:39+00:00
    Yes - all surfaces need to find a new balance in what the capacity really is. Per the FAQ, it will take five charge and discharge cycles to relearn the actual battery capacity.
    I think there is no reason for concern but its worthwhile to check it regularly...
    2016-09-09T04:23:26+00:00
    10 days have passed since the update.
    My SP3 looked recovered at that time, but now seems degrading again drop by drop for these three days.
    Has the issue really fixed completely? Isn't that just a stopgap?
    2016-08-15 - 2016-08-22 144 mWh 42,157 mWh
    2016-08-22 - 2016-08-29 144 mWh 42,157 mWh
    2016-08-30 19,975 mWh 42,157 mWh
    2016-08-31 35,910 mWh 42,157 mWh
    2016-09-01 36,987 mWh 42,157 mWh
    2016-09-02 37,620 mWh 42,157 mWh
    2016-09-03 37,620 mWh 42,157 mWh
    2016-09-04 39,113 mWh 42,157 mWh
    2016-09-05 40,234 mWh 42,157 mWh
    2016-09-06 39,883 mWh 42,157 mWh
    2016-09-07 39,611 mWh 42,157 mWh
    2016-09-08 39,223 mWh 42,157 mWh
    2016-09-07T17:58:44+00:00
    I have ran the new firmware and it seems to have helped the battery.
    Before the install if I were to disconnect the power the Surface would go from 100% to 6%.  Now I have had it discharging for about 20 min with no issues.
    I'm letting it discharge now and will update
    *UPDATE*
    Battery fully discharged.  One issue upon  first drain the battery showed 100%.  I wasn't till it was dead did it show an accurate charge.
    2016-09-07T07:37:59+00:00
    Thank you Barb, I'm writing the message using my SP3 with an SP4 AC adaptor powering the unit and unfortunately nothing has changed. I deleted Microsoft  ACPI-compliant control method battery and restarted the computer, I even rolled back the the firmware drivers and tried to reinstalling them, but nothing has changed. (Code 14) I'm just waiting for Microsoft Japan to get back to me regarding this issue.
