2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-09-05T13:19:53+00:00
    I don't expect the docking station to work. Can you find a friend with a SP3 or
    SP4 or Surface Book and try their charger?
    >> I tried my docking station and the original charger, both won't work.
    2016-09-05T12:20:11+00:00
    Hi Budi,
    I tried it, but the only "success" I recently had was the light of the keyboard flashing for a second when I tried to start the Surface in the docking station with external display...
    I'll ship it in this afternoon.
    2016-09-05T12:05:23+00:00
    Hi Marlin,
    I got the same situation like yours.
    After battery not detected then i update the firmware and the battery 100% used by the application.
    After that i can not start the SFP3, nothing show up on the screen, event the 2 buttons hold down for 20 seconds, unless a litle light on keyboard.
    I tried for 3 times hold down the 2 bottom, still same result, no response.
    Finally i try SFP3 connect to external display, and it's work so i can backup my data.
    But i still got the battery not detected and blank screen after update the firmware, very dissapointed.
    Rgds,
    Budi
    2016-09-05T10:26:26+00:00
    Hi Barb,
    thank you for you quick response. I tried my docking station and the original charger, both won't work. Since I still have warranty, I'll send my Surface in and say farewell to my data...
    In my opinion, the update destroyed the battery control unit and, therefore, killed my Surface.
    One other, slightly annoying thing is the customer service in Germany: You can schedule a call and they call you back later. Now, they call me to tell me that customer service is only availably during working hours (9-6). It is currently noon... even better, I scheduled a call to my fixed-line phone and now, they call me every 30 minutes to tell me this...
