2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-09-04T16:17:44+00:00
    Mates, My SP3 i7 256 Gb + SIMPLO X898289, previously stuck at 144 mWh first jumped to 35,910 mWh right after the FW, and today I am happy to notice I am at 37,704 mWh.
    I am at 499 cycles. I am not expecting much more increase since my SP3 is a 1.5 year old, but who knows...
    Got another capacity increase...
    144 mWh :( -> last FW update :| -> 35,910 mWh :) -> 37,704 mWh :)) -> 39,588 mWh :D
    Thanks Microsoft for fixing this ! ;D
    2016-09-04T15:39:18+00:00
    I was hoping the new firmware update would solve my problem but it did not. I have tried every solution I have found here, but no success. The problem is that my battery indicator is stuck at 99% regardless of usage.
    Here is my battery report:
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=cd2873a3-bf13-4538-a8ff-50f2bb1340ae)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=615a562c-c8ce-44c7-a34f-c645ed4d54fa)
    As you can see, the capacity is stuck at 35895mWh.
    I have the exact same experience and the new firmware update does not solve this issue...
    2016-09-04T15:38:50+00:00
    Thanks for the answer!
    Unfortunately charging with the SP3 on/off is also something that I have tried, without success. It seems that MS still have not fully resolved the bugs surrounding the "fuel gauge" as my SP3 is still unable to determine the remaining capacity of the battery.
    2016-09-04T15:25:15+00:00
    I sent an email, not the same as opening a ticket. I don't always get detailed
    feedback, mostly "engineering is looking into this".
    >>You have opened a ticket to MehdiSeyedain's issue, which is exactly my problem now. Let us know if MS comes back with any workaround.
