2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-09-04T06:49:20+00:00
    First, you should be able to power on using the power adapter that came with the
    SP3 (but possibly not in the dock).
    If the battery is not being detected, you may have a different issue. Can you
    power up from AC and run
    powercfg /battery report
    and post the results here.
    Second, at this point, I would not advise applying the battery regedit at all.
    Hi Barb,
    This Sunday I booted up the SP3 from AC power and tried to install the firmware.
    As no battery is detected the firmware won't install.
    Can you please ask MS to remove this minimum 40% battery power restriction before any update is installed?
    It's a catch 22 situation I need to get out of.
    Give me an msi or something that I may run without facing this 40% battery barrier, please.
    Here's the battery report you asked for. The rest of the report is just blank and irrelevant.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=7dca9d7d-689c-4078-9cd4-6aedad3085fe)
    Your issue is not the same as others. Others can actually see the battery and it's capacity. Maybe your battery is actually dead.
    2016-09-04T03:34:28+00:00
    Hi Barb,
    2016-09-03T17:48:33+00:00
    After much irritation and finally being able to boot my bricked SP3 (with a SP4 charger) the upgrade installed and battery capacity now back to 35,910. Surface is once again working and back to loving the product.
    It took a while but thanks to Microsoft for finally coming through with the fix.
    2016-09-03T11:02:51+00:00
    Hi Kevin,
    I had the same issue as you during the 1st and 2nd battery cycle, after the update. I do my charging while the SP3 was OFF. When I thought about having to cycle the battery capacity several times for the SP3 to "learn" the capacity, I attempted to charge it while it is ON. I am now on my 3rd cycle and I am "glad" to observe the battery percentages are falling (kind-of) normally. The only thing that still does not work well is the capacity did not reached 100% during charging. I am feeling a little positive and look forward to see what happens after a few more cycles. Not sure if we indeed have the same issue, but that was my encounter. Hope it is useful.
    CP
