2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-09-02T09:41:05+00:00
    I've emailed my internal contact with this info. No guarantees anyone will
    respond. Doing what I can..
    2016-09-02T01:29:10+00:00
    Hi Barb, I've been speaking to Microsoft Japan to try and resolve the situation and they've just asked me to send them the battery report information also.  Below is what is left of my battery information after numerous OS installs.
    Hope this helps.
    Battery report
    COMPUTER NAME DJPRO3
    SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
    BIOS 3.06.0350 04/25/2014
    OS BUILD 9600.18423.amd64fre.winblue_ltsb.160723-0600
    PLATFORM ROLE Slate
    CONNECTED STANDBY Supported
    REPORT TIME 2016-09-02 08:08:01
    Installed batteries
    Information about each currently installed battery
    NAME X863568
    MANUFACTURER SDI
    SERIAL NUMBER 291E
    CHEMISTRY LION
    DESIGN CAPACITY -
    FULL CHARGE CAPACITY -
    CYCLE COUNT -
    Recent usage
    Power states over the last 3 days
    2016-09-01 18:35:58 Active AC - -
    18:35:58 Suspended - -
    18:38:59 Active AC - -
    18:38:59 Suspended - -
    18:40:33 Active AC - -
    18:46:00 Suspended - -
    18:50:13 Active AC - -
    18:50:13 Suspended - -
    18:53:24 Active AC - -
    18:53:24 Suspended - -
    18:57:43 Active AC - -
    21:11:56 Connected standby AC - -
    21:54:07 Active AC - -
    22:04:09 Connected standby AC - -
    22:31:15 Active AC - -
    22:41:17 Connected standby AC - -
    22:41:21 Active AC - -
    22:51:23 Connected standby AC - -
    22:51:26 Active AC - -
    23:01:27 Connected standby AC - -
    23:12:24 Active AC - -
    23:22:24 Connected standby AC - -
    23:58:27 Active AC - -
    2016-09-02 00:08:29 Connected standby AC - -
    00:11:29 Active AC - -
    00:21:31 Connected standby AC - -
    03:43:14 Suspended - -
    03:57:55 Active AC - -
    03:57:55 Suspended - -
    04:00:38 Active AC - -
    04:10:28 Connected standby AC - -
    06:29:47 Suspended - -
    06:34:07 Active AC - -
    06:51:20 Connected standby AC - -
    06:57:56 Active AC - -
    07:22:00 Suspended - -
    07:24:39 Active AC - -
    07:30:00 Suspended - -
    07:38:29 Active AC - -
    07:44:00 Suspended - -
    07:49:14 Active AC - -
    08:00:00 Suspended - -
    08:02:41 Active AC - -
    08:08:00 Report generated AC - -
    Battery usage
    Battery drains over the last 3 days
    Usage history
    History of system usage on AC and battery
    Battery capacity history
    Charge capacity history of the system's batteries
    Battery life estimates
    Battery life estimates based on observed drains
    Current estimate of battery life based on all observed drains since OS install
    Since OS install - - - -
    2016-09-01T20:03:30+00:00
    Mathew, thank you for the reply.  The driver version is 38.10.90.0.  I remember reading that this is the version I am supposed to have.  Also while most of the time I use my SP3 docked, while installing the update I removed it from the dock as per the instructions.  I will do another battery charge cycle to see if it helps.
    2016-09-01T19:41:13+00:00
    I have the same issue with one the SP3's in our business.  Unfortunately, the Surface doesn't power up even though the light is lit on the charger (I have also tried numerous chargers). I have ran through the usual power button down for 30 seconds along with power button / volume button for 15 seconds to no avail. I spoke with MS support and they told me that the device would incur over a £200 charge as it's out of warranty.  The Surface was only holding >30 minutes charge when on battery.  It's extremely unfortunate that just as the fix has been released that the Surface Pro wont power up.
    According to the FAQ for the fix I’m to go to a local Microsoft store
    My Surface Pro 3 won’t boot on AC power for me to install the update. What should I do?
    Ensure that you're directly connected to AC power. Don't use the Surface Pro 3 Docking Station. Also make sure that you don't have any USB peripherals or external monitors plugged into the device.
    Make sure that the light on the tip of the power supply where it connects to the Surface Pro 3 is lit and not blinking. If the light isn't on or is blinking, there may be a problem with your power supply. If the light is on but the device won't boot, try reversing the direction of the connector to the device to ensure proper contact.
    You can also visit a nearby Microsoft store location and ask a Microsoft Answer Desk technician for assistance in powering the device and applying this update.
    As we are based in the UK visiting a store wont be possible.
    At the moment I have a £800 device sat on my desk with a fix I’m unable to apply due to the device not powering up.  Surely Microsoft should be liable for replacing this now given they have admitted fault with the battery fix?
