2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-31T14:05:00+00:00
    Engineering is putting some steps together for you and Linda to try. They said it will be a few hours (it's only 7am in Redmond). I'll post when then provide the process.
    2016-08-31T13:45:33+00:00
    Mine is 35,910 too ... funny if they hard coded this number lolz
    If they are hard coding the levels, what is REALLY going on with our batteries?
    [morpheus' voice]
    what if i told you that the design capacity is also a hard coded number... because it is impossible to know what the actual capacity is? everything is an approximation.
    [/morpheus' voice]
    2016-08-31T13:38:33+00:00
    As of last night mine was up to 37000ish so is going up
    2016-08-31T13:34:34+00:00
