2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-21T13:17:46+00:00
    Haha - less than that. Mine has been on life support for more than 4 months. Microsoft's Easter egg happened just outside warranty. (13-14th months from purchase I think) I am ok to boot without micro SD or run voice recorder in the background to eliminate one high CPU load task or kill another CPU hog occasionally, but it's absolutely nonsense to render a portable device useless by zeroing its battery and not taking full responsibility for it. Shame on you Microsoft!
    Thing is I have already advised a good couple of people against buying a surface and will continue to do so. MSFT is shooting themselves in the leg with such unprofessional attitude.
    2016-08-21T12:41:55+00:00
    I went to the park meadows store today to get my Simplo SP3 replaced.  They gave me a new one - LGC battery with only 15 cycles.  Good news I thought.  Well, this one is stuck at 54% battery plugged in not charging.  Won't run unless plugged in.  Dies immediately if I unplug it.  Won't boot without a power cord.  I tried 2 power cords with the same result.  This is my 3rd defective SP3.  About ready to ask for a refund to buy somebody else's product.  I'm out of patience.
    At least they did something for you.  I have been to that store twice and they will do nothing for me.  Their attitude is that it's normal for a laptop to last 18 months these days.
    2016-08-21T10:52:20+00:00
    Nope - looks like they might consider offering you a refurbished SP3 if you make your voice heard and seem to be well informed of the issue, but apparently they don't want everybody to go that route as a magical fix is being cooked behind the scenes which may or may not put an end to this misery.
    2016-08-21T10:06:30+00:00
    Me too have this issue.
    Do you think that a replacement for a new model could be asked?
