2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-20T03:41:19+00:00
    Ya'll  have a right to be upset..  BUT ... sometimes it takes time to identify, remediate, test and deliver a fix.
    So Greg doesn't get thrown under the bus.. you all can go to TWITTER  and see that Panos Panay himself tweeted the fix is close and is a SOFTWARE fix...
    Likely this issue is with the interaction between the system firmware and how it reports and reads the battery level during charging.  So I would expect the fix would yes return the battery to full capacity as it would both properly report the battery level AND initiate charging properly based on the correct level.
    Sorry you all have had SP3 issues I am in IT and we buy lots of SP's (3's and now 4's) and have very few with this issue.
    Regards,
    I wouldn't minimize the frustration here, especially for those who have paid $99+$450 for a replacement (without any mention so far of making it right). Or for those who have a brick and are waiting for a magic update via some new process..? maybe Necro.. WSUS.. Osmosis?
    Since 95 pages and 4+ months of complaining has only yielded this much progress, I would encourage more criticism.
    2016-08-20T03:30:45+00:00
    Yeah, I am asking in forums in Singapore and doesn't seem anyone have this problem, or no one bother to reply me there. Is yours SIMPLO batteries? If yours is still under warranty, have you tried contacting to Microsoft yet for replacement?
    2016-08-20T02:20:22+00:00
    Looking at the currency, it seems like you are from Singapore. Can I know what model battery are you using and what have the battery degraded to?
    I also want to know what we in Singapore can do ?
    I will try the registry tweak to see if it allows the unit to at least run with power supply first.
    No battery detected now in my SP3.
    Nobody from MS has come up with a fix as yet.
    I'm fearing the worse.
    Thanks.
    2016-08-20T02:15:41+00:00
    So the day before Greg's new announcement, I decided I wouldn't be able to wait any longer, so...
    I took my device to my local retail Microsoft Store, showed them this thread, and after running a few tests, they agreed to swap it for a new (probably refurbished) Surface Pro 3! What's better is that my SquareTrade extended warranty should transfer to this new machine once I provide the documentation.
    Warning: the Windows 10 File History 'backup' operation did not work properly, and neither did my attempt to restore from a system image. So, after taking it back to the store to reinstall Windows again, I will be spending the weekend manually transferring files from my backup hard drive.
    But at least I have a working LGC battery. For now.
