2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-18T17:04:37+00:00
    Questions will be asked. I was also told My warrantyfor the new device would end when my original one does, In a month. However their terms and conditions say 90 days. Other people have been told that too.
    Consistency seems t be a word Microsoft are yet to learn.
    2016-08-18T16:29:03+00:00
    So, I received my replacement surface today, as I contacted MS during my year warranty.
    Funny how those in warranty seem to be treated completely differently.
    Well, I received it and decided to have a look at the battery. Design capacity 42k, actual capacity, 40k. Cycles, 417.
    The display driver crashes constantly, every time I press start to be precise, every app I open crashes too.
    Things are off to a good start.
    Maybe it's just me, but I don't know how happy I would be if I returned a Surface with a defective battery only to get a different one back that already has a battery with 400+ cycles on it. I would think their refurb process should at least provide a unit with a fresh(er) battery.
    2016-08-18T16:25:32+00:00
    Hi Rocco,
    Are you able to share the incident reference number? This would be a huge help for those people who are being consistently referred to extortionate refurb costs as they will be able to refer to this to move forward with some recognition that there is a way to get a working device.
    Stu
    2016-08-18T16:23:46+00:00
    For those who have exchanged (either with a fee or not)...aren't you concerned you are getting a refurb that will have the same issue?
