2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-18T15:14:37+00:00
    UPDATE:
    I just received the following email from Microsoft after linking to this thread.
    "Good morning ******,
    I have brought your issue to my manager’s attention and he has approved and out of warranty exchange free of charge. He stated that your device qualifies to be included into the ongoing investigation regarding this issue. Once you receive the replacement device, a 90-day warranty will be added. If you wish to continue with the exchange, please fill out the shipping information form at the bottom of this thread. Thank you for time and patience during this process.
    Kindest regards,"
    So maybe a little leverage is all that's needed!
    2016-08-18T14:58:30+00:00
    Apple, who released an update that deliberately bricked iPads that had a third party repair on the fingerprint sensor, told the world it was by design and buy a new iPad. then ages later said sorry it was a mistake, backed down and released a new update to "fix" the issue, not sure what apple did regarding everyone who had to buy a new iPad or pay for an out of warranty replacement on that either....
    manufacturers are all the same!
    TBH i'm glad MS are trying to do a software fix for devices that are out of warranty (probably because many are still in warranty!) but not sure how it will work for devices that will no longer boot (USB boot and patch?)
    I don't like the apparent silence from MS on progress but i know that software patches take ages to thoroughly test and would prefer not to receive updates like:-
    testing patch
    still testing patch
    still testing patch
    still testing patch
    If Microsoft are providing a software fix, it is because there is a software fault. They have an obligation to fix their buggy code. More importantly, if it is a software issue, that means one of their updates caused this, as 12-18 months of no issue, followed by most of the SP3's starting to die around April / May, indicates a software update about that time. If this is the case, not only should Microsoft fix what they broke, they should compensate those who they affected, because they have essentially put malware on many SP3 devices that have bricked them worse than any virus infection.
    2016-08-18T14:54:56+00:00
    I am having this problem, too.  I also have a simpro battery with only 115 cycles.  It won't take more than a 144 mWh charge.  I can limp the thing along plugged in, but will not take a charge and for the last half year has not been able to function unplugged, which is why I bought the thing.
    I have been through numerous, lengthy calls with Microsoft support, and they told me I could buy a warranty replacement refurb surface for $400.  The battery failed shortly after the warranty expired.   115 cycles is way too few for a $2,000 tab.
    I would like to have a better fix.
    This article discussed a class action probe.
    http://www.infoworld.com/article/3102031/microsoft-windows/microsoft-surface-pro-3s-defective-simplo-batteries-trigger-a-class-action-probe.html
    2016-08-18T13:54:41+00:00
    can you power it on without the dock, just with the power cord/brick adapter or
    not?
    >> 90% of the time it won't come on even when connected to power/dock.
