2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-18T12:27:18+00:00
    I have found it helpful to disable to battery driver.
    2016-08-18T12:23:55+00:00
    Mine will function with a direct AC to outlet power cord but not when powered through the dock.
    2016-08-18T12:23:49+00:00
    I've been having a discussion with Barb Bowman on twitter around the SP3's that are so low on capacity that they no longer function when docked.  Are there SP3 owners on this topic that are also finding that the SP3, when at it's lowest capacity, is also unable to stay on even using the supplied power supply?  I'm sure some people said that was the case but we want to be sure.
    It was the case for me, I just twitted to you (Full_Options). Here are more details about my setup :
    I am only at the lowest 144 mWh. This week-end I could barely boot on basic adapter and not at all on the dock... After reading few post here and there, I did this :
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=f829a244-0d04-4710-bb79-19f67c3846cd)
    Just in case and not sure if it really helps, I also lowered the "turbo boost power max" wattage with Intel XTU tool :
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=f3b28642-4baf-41df-bc0f-03477588ac2e)
    I can now use barely normally use my Surface Pro 3 even if showing only 144 mWh, and of course as far as I keep it plugged to a basic AC adapter or the dock. HTH
    2016-08-18T12:22:55+00:00
    That's the case for one of mine.  Battery degraded down to 144mWh from 42,000mWh in the space of two months.  It dropped nearly 50% the first week, then a few thousand every week thereafter.  Two months after the warranty ended.  90% of the time it won't come on even when connected to power/dock. Soooo.... recall anyone?
