2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
If you’re having trouble charging your Surface, you get a low-battery error, or your Surface turns off when you unplug it, the steps in our Surface battery won’t charge article can help you pinpoint the problem. Should you need any further assistance, please contact us.
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-12T18:21:22+00:00
    I'm not sure if anyone else has done this but I've created a bitly link that people can use in emails/letters to refer to this topic in case they want to refer customer service people here when discussing replacements:
    http://bit.ly/SP3BatteryGate
    2016-08-12T18:14:56+00:00
    Warranty exchanges being for refurb pieces, that's standard practice with notebooks/laptops as far as I am aware. As long as the exchanged piece has the right amount of battery, which you can test by running powercfg, why not just exchange and get it over with?
    Make sure you run Powercfg right there and then, and save it someplace safe. You should also try and see if they will extend the warranty to another year from the date of exchange.
    2016-08-12T18:14:35+00:00
    The only information we have is that posted by Greg, see first page as it's pinned due to being voted "helpful", where he states they believe it can be corrected with a software/driver update.
    I purchased my SP3 from John Lewis in the UK and so have 3 years warranty, of which I'm about 18 months through, but am holding on to find out if it can be fixed by software because I also look after my devices and so do not want a refurbished replacement.  I also don't want to get that replacement only for Microsoft to then announce a refund/recall program IF they realise it can't be fixed with software.
    If the warranty you have is coming to an end then I'm not sure what I would do in your position.  Microsoft should be contacting people with unusable devices and treating those as special cases.
    2016-08-12T18:01:17+00:00
     I think the bug will be fixed, but by the time the fix is applied, flat batteries that are charging to 144 mWh are irreparably damaged and the fix will remove the cause, but won't undo the damage.
    And what are you basing this on?
    The software that is measuring and estimating the battery capacity is lying.  Microsoft confirmed that.  But you have no idea what part it is lying about.  You're guessing the 144 mWh capacity part is correct when it is one of the most likely numbers to be in error.
    The iFixit teardown someone linked to revealed a fancy "fuel gauge" IC with a lot of black magic in it.  That is probably where the problem is.  Until there is more information, the FUD is not helping.
    The FUD is quite justified.
    The computers are not working and there has been no confirmed fix, only an unsubstantiated comment on this forum which the rest of Microsoft support seem unable to verify.
    People are speculating on the cause of the problem because there is no other reliable information.
    Microsoft have sold a product which has failed in an unreasonably short time period and doesn't perform as advertised. They obligated to make good such faults in a reasonable time period and IMHO their silence on the matter seems to indicate they are either unable to find a fix or are trying to avoid that obligation.
    Given that this problem has been reported on these forums for several months now people are quite justified in seeking remedies other than the fabled software fix and indeed quite justified in doubting that a software fix is actually possible.
