2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
If you’re having trouble charging your Surface, you get a low-battery error, or your Surface turns off when you unplug it, the steps in our Surface battery won’t charge article can help you pinpoint the problem. Should you need any further assistance, please contact us.
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-12T17:20:13+00:00
    And what are you basing this on? The software that is measuring and estimating the battery capacity is lying.  Microsoft confirmed that.  But you have no idea what part it is lying about.  You're guessing the 144 mWh capacity part is correct when it is one of the most likely numbers to be in error. The iFixit teardown someone linked to revealed a fancy "fuel gauge" IC with a lot of black magic in it.  That is probably where the problem is.  Until there is more information, the FUD is not helping.
    @mbulger
    You sound more intelligent than most of the gimps that hang in these kind of threads.
    I don't suppose you can spare a minute to address my post? (couple of posts above yours)
    Thank-you.
    2016-08-12T17:11:18+00:00
     I think the bug will be fixed, but by the time the fix is applied, flat batteries that are charging to 144 mWh are irreparably damaged and the fix will remove the cause, but won't undo the damage.
    2016-08-12T15:49:14+00:00
    What's the latest on this, is it really truly a dvr/fw issue, as MS officially claimed at one point, & if so when the heck is it going to be fixed?!?
    I can't wait much longer, going to go through a return process soon, already teed it up, but thought I'd wait over the weekend before executing it all.
    Not happy, they can't guarantee a new unit*, only a refurbished one, it better bloody be in pristine condition, & not a much older LOT/Batch number!
    Thank-you.
    *my SP3's WELL within warranty
    2016-08-12T15:29:21+00:00
    I'm not an expert on the matter but what I understand is that they can recover the loss in battery life. They may be working on some kind of battery re-calibration software to recalibrate the battery....who knows.
    Thats what I understand!
    But it might be a matter of chemistry now? A Lithium Ion battery run dry and cycling to the minimal charge, every time you plug it in, might be damaging to the battery itself, so when the software fix is released, the batteries ability to be charged would be gone, because the chemical properties of the battery are now at a state that's the equivalent of many years of use and hundreds of charge cycles? In other words, this issue might be accelerating the aging process of the batteries.
