2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
If you’re having trouble charging your Surface, you get a low-battery error, or your Surface turns off when you unplug it, the steps in our Surface battery won’t charge article can help you pinpoint the problem. Should you need any further assistance, please contact us.
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-11T14:41:46+00:00
    The value of 2 enables the option to throttle the CPU, to set it to 65% you have to go into the advanced power options (go to Control Panel\All Control Panel Items\Power Options\Edit Plan Settings, then click Change advanced power settings)
    2016-08-11T14:40:36+00:00
    I am seeing a lot of references to this happening at about 15 months of ownership which is also when it happened to mine. I wonder if there is any significance to this time period? Or is that just when they started to switch battery suppliers to LG?
    This issue is not only on SIMPLO, is affecting LGC batteries as well. Mine have lost 33% of its total capacity, some have reported more degradation on LGC, I believe as time passes LGC is going to catch up with SIMPLO. Also, is not that before was SIMPLO and later they switch to LGC. I bought my surface exactly on day 1 of release and it came with an LGC battery.
    2016-08-11T14:27:13+00:00
    From my limited understanding of legal matters, the class action route is the mechanism by where we as individual users will benefit.  A larger organization could sue on their own behalf and win, but that would not mean Microsoft has to make all SP3 users whole.
    2016-08-11T14:20:21+00:00
