2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
If you’re having trouble charging your Surface, you get a low-battery error, or your Surface turns off when you unplug it, the steps in our Surface battery won’t charge article can help you pinpoint the problem. Should you need any further assistance, please contact us.
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-11T12:38:10+00:00
    My failed Surface Pro 3 with Simplo battery ended in 5153.
    2016-08-11T12:33:42+00:00
    Likewise.  I have another one with:
    X898289
    SIMPLO
    This one also has a s/n on the Surface Pro3 then ends in 5353 and the warranty expired on 4/12/16
    2016-08-11T12:20:53+00:00
    I have the same:
    X883815
    LGC-LGC
    One other thing to note.  All mine that are dying have a s/n that ends in 5353 and the warranty expired on 4/12/16.  Makes you wonder??
    2016-08-11T10:58:50+00:00
    anyone with LGC LGC batteries facing the same issues???
    Yes.  It's not as bad as what the SIMPLO people are reporting.  The maximum battery-powered life my Surface Pro 3 gets is about 3 1/2 hours.  Near the end it reports "Your battery is low ... 10%", "Your battery is very low ... 6%" then complete power off all within LESS THAN A SECOND.  At that point I can't turn the machine on anymore, plugged in or not.  If I let it sit with the charger on for about half an hour I can use it again (plugged in).
