2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
If you’re having trouble charging your Surface, you get a low-battery error, or your Surface turns off when you unplug it, the steps in our Surface battery won’t charge article can help you pinpoint the problem. Should you need any further assistance, please contact us.
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-11T06:06:29+00:00
    anyone with LGC LGC batteries facing the same issues???
    There are some owners reporting this with LGC batteries but the majority are Simplo batteries.  We don't know how many SP3's have been sold or what the ratio of LGC to Simplo batteries are so it's possible these few LGC batteries are just random failures rather than directly related to the battery degradation.
    Wouldn't it be great if Microsoft were actively responding to people asking these questions?
    I emailed Satya Nadella yesterday so maybe that will get some attention even if I don't receive a direct response.  People in the Surface division should be getting fired over these multiple generations of Surface issues.
    2016-08-11T05:18:04+00:00
    Can show does your wife regularly use the sp3?  I'm so using sp3 with lgc batteries but the full charged capacity now is already down to 39k with only 180 cycles.
    2016-08-11T05:03:39+00:00
    My wife's SP3 uses LGC battery and is in perfect condition. Actually it's at about 44000/42000mwh.
    2016-08-11T04:55:13+00:00
    I started getting this issue also. According to the battery report the degradation started right after 15 months. Now it barely lasts 2 minutes on battery.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=221cbb29-f66f-43e8-b8fd-15b9d6bd242c)
