2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
If you’re having trouble charging your Surface, you get a low-battery error, or your Surface turns off when you unplug it, the steps in our Surface battery won’t charge article can help you pinpoint the problem. Should you need any further assistance, please contact us.
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-11T01:03:21+00:00
    I'm not sure if this has been discussed in the thread already (at 64 pages long I could have missed it), but an issue I didn't notice until my SP3's battery capacity fell below 300mWh is that when it is under heavy load (including when it is starting up) it draws more power than the AC adapter can provide and the battery had gotten to the point where it was just barely able to cover the shortfall.
    To avoid reaching a point where the Surface was unable to boot-up, I set the "Maximum processor state" to 65%, which seems to keep the system within the limits of what the AC adapter can provide. This option is not available by default in the Power Options for the Surface. However, adding the registry key below will make the option visible in the advanced power options menu.
    HKLM\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\54533251-82be-4824-96c1-47b60b740d00\bc5038f7-23e0-4960-96da-33abaf5935ec
    Add: DWORD
    Value Name: Attributes
    Value Data: 2
    Does it mean that value data 2 translates to 65%?
    What is the value data for 60%, a fraction of 2?
    2016-08-10T21:25:24+00:00
    Add me to the list. 15 months used surface pro3 with SIMPLO battery. My current battery capacity is 13500mWh. Ironically I feel lucky(seeing other cases here) even though 70% of my battery has degraded in the period of 16 months. Bought it in Finland and the retailer had warranty of 2 years, but they are refusing to take it back since battery is not covered in the warranty after a year.
    2016-08-10T18:48:57+00:00
    Plus 1 more on the SIMPLO battery issue. I don't have a battery report to share as I had already installed the Anniversary Update, and used USB recovery (After the SP3 shut off during the built in recovery option) but my issues started with "Not Charging" in May. In the past week, my Surface began powering off, even when docked.
    I currently have a cycle count of 173 with Full Charge Capacity of 144 mWh. The dock is basically a paper weight and my SP3 is not far behind.
    I am trying patiently to wait for an answer on this, but it seems to be dragging on quite a bit with no updates from Microsoft. I get the CYA aspect, but give us something!
    2016-08-10T18:36:30+00:00
    Has anybody tried reaching to their friends/relatives in MSFT? Not to see if there's a solution, but rather to see whether this issue is also with all their dogfooded SP3s? Or did they already replace all SP3s with SP4s?
    I reached out to someone in IT, and according to them the issue was resolved in Anniversary update which clearly isn't the case.
