2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-09T09:46:46+00:00
    Hi juanmaq,
    I'm really interested in using your method to restore the battery but I still not sure how you do it. you mean is that
    1. after you fully charged your surface pro 3, you turn off the surface pro 3 and let it in off state for a few hours or half a day, then after that you turn on and use it normal only up to 50% to 60% battery left, then you put it to charge again?
    2. any specific settings that you use during charging? Do you need to have it switch on with the screen turn on and brightness at the lowest during charging to full? or can turn it to sleep or turn it off and leave it to charge to full?
    Please help.... appreciate it
    2016-08-09T02:28:55+00:00
    Just took mine to the Microsoft store in Vancouver (Metrotown store).  They advised me that since I was six weeks out of warranty that I would have to pay $580 for replacement.  They appeared to be aware of the issue and were not interested in even looking at my Surface.  They said they had heard is was a software issue and that a fix was being worked on.
    2016-08-09T01:10:37+00:00
    Wow and your SP3 was out of warranty?!
    Yes, i had a geek squad protection plan. Just in time too, it was expiring today.
    Interestingly, the clerk there said they had never heard of the battery issue yet, but knew something was up when MS suddenly pulled their SP3s from the shelves.
    2016-08-09T00:52:02+00:00
