2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
  1. Deleted
    2016-08-08T01:47:37+00:00
    Has anyone else had any luck getting a refund from Best Buy? Or just the one? I'm going to try asking tomorrow.
    2016-08-08T01:27:24+00:00
    Make sure you all take a minute and go to the Microsoft store to post your review of the product and the support you've received so far on this issue.
    https://www.microsoftstore.com/store/msusa/en\_US/pdp/Surface-Pro-3/productID.300190600
    I just did (8th August 2016).
    So did I.
    Can't see the comments though... So whether they get past the MS moderators will be intetesting.
    I posted mine and it went through, but shortly after, has either been blocked or removed. I suspect many are being removed.
    Isn't that illegal?
    2016-08-08T01:22:20+00:00
    So did I.
