2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-06T21:59:06+00:00
    Do we leave it unplugged?
    I am down to 200mWh.  I don't know if it will stay on long enough to install any updates.  Even plugged in it shuts donw
    2016-08-06T21:57:57+00:00
    emailed adding my name to list of people.  sick of the no reply and support people hanging up on me.
    2016-08-06T21:51:32+00:00
    I am having this issue and have used my surface.  It is down to 200mWh.  I am worried that I won't even be able to install firmware when it comes out.  I am now leaving it unplugged.  Is that the right thing to do?
    This is only a few months after having it for a year.
    When is the update expected?
    Why does support hang up on me when I try to ask them questions?
    I will never buy a microsoft product again.
    2016-08-06T21:34:40+00:00
    Thank you!😊 I am aware that they are US based solicitors (and I live and purchased my Surface P3 in the U.K.) however I have emailed them my details. Following my written response from Microsoft it's clear that the only valid course of action now is legal.
    http://www.classlawdc.com/2016/07/26/migliaccio-rathod-llp-investigates-microsoft-surface-pro-3-battery-failures/
