2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-06T18:40:21+00:00
    i posted this at the top of page 2 of this thread
    ______
    I bought my pro 3  from PC world in  sept 2014 ,i rarely used it only when away from home
    Feb  this year i had the not charging  90% battery but every time i took the charger off it died
    went through all the steps with the support and was told it was battery failure and would have to have it replaced out of warranty  for £260
    they then told me I should  take it back to the shop under EU legislation it should be guaranteed for at least 2 years under faulty goods act
    i went into PC world who fobbed me off and told me i had to contact head office about out of warranty
    I contacted PC world by phone and they got back to me an hour later and told me they do not repair tablets and i had to take it to a shop for repair and they would pay the bill
    I contacted a computer shop and was told its a sealed unit and they would not  attempt to replace the battery
    I phoned PC world the next day and got a different person in the dept who told me he has had a few problems with them and yes its a sealed unit and can only be fixed properly by replacing the unit , he then told me his manager was out and would speak to him about making me an  offer
    he phoned back 15 mins later and offered me £532  as i had already had 18 months usage from it
    I took their offer
     I still have the pro3 but when i contacted microsoft about a replacment  the price had gone up to £400  only a week later and its only 3 month warranty with the replacement
    same thing could happen in 6 months time  as i had very little usage on it maybe 3 or 4 times for about 3 weeks at a time
    I can still use it when its plugged in so have not replaced it yet
    ______________
    I am now down to 8% and soon to be a brick
    2016-08-06T18:21:01+00:00
    Just tried returning mine to PC World in UK.
    No authority to approve returns in store apparently. Need to go through their head office escalation team.
    Already they are saying they wan't me to get an independent assessment to prove the fault existed when I purchased the 'brick'. If they continue with that approach, rather than accepting that multiple reported failures are sufficient proof, does anyone here (who is more technically minded than me) know what sort of assessment would be required to prove a battery was faulty when purchased?... Is it actually possible to do that?
    2016-08-06T13:02:51+00:00
    How did you manage that and how far out of warranty was it? I can't even get past the repetitive quote "it's out of warranty" (by 6 weeks when it died).
    Just had Microsoft replace my SP3 with simplo battery out of warranty  for free with a cracked screen none the les at the store! Awesome!
    2016-08-06T10:16:57+00:00
