2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-04T09:25:04+00:00
    Is yours an i7 or which SKU?
    2016-08-04T03:49:34+00:00
    Another path to explore if you're willing to get your Surface repaired: check if your credit card offers an extended warranty.
    Most premium credit cards offer to double your warranty up to one year if you pay for your entire purchase with your credit card.  Worth checking into if you can afford the downtime of a repair.
    2016-08-04T02:54:20+00:00
    For a fan, this is the way to go:
    https://www.amazon.com/ARCTIC-USB-Powered-Portable-Solution-Gooseneck/dp/B003XN24GY/ref=sr\_1\_4?ie=UTF8&qid=1470279139&sr=8-4&keywords=usb+fan
    The flexible USB one you can take with you - of course it draws power - GRRR, but there is also one with a base and speed adjustment that you can plug into a hub and get power from that.
    2016-08-04T01:08:17+00:00
    Well, I just checked and mine has the same name. I bought mine on January 2015.
