2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-06-24T14:02:17+00:00
    Teperature processor exceeds 80 degrees and the same tablet in the right part is so hot that it is difficult to maintain. This is a felerny product! In another thread you can find people with damaged battery.
    http://answers.microsoft.com/en-us/surface/forum/surfpro3-surfhardware/surface-pro-3-2-hour-battery-life/ad93eb3a-3dc4-40f0-9ee6-afa4f090886f?page=2
    My first SP3 and my replacement (current device | i5 8GB) both experience(d) high core temperatures (while browsing facebook, watching videos on youtube, etc.)
    Did not damage my battery (being used for a year)
    However, battery life goes down to about 4 hours on full charge while watching videos (on Chrome or IE; Windows 10)
    Windows 8.1 seemed to get me much more battery life though. I could read a pdf(1355 pg, with images) at 25% brightness on airplane mode for 9.5 hours on full charge, Windows 10 gives me much less
    Will post updates if battery degrades rapidly
    2016-06-24T13:21:20+00:00
    2016-06-24T11:14:00+00:00
    Thank you - that is very suggestive of a battery manufacturing problem.
    I guess we need about 1000 owners to complain before anything gets done
    2016-06-23T04:32:25+00:00
    This is the result from my surface (got it replaced a year ago (May 29, 2015))
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=c83f8b22-3454-4cf7-8565-4f7ea63694ba)
    Manufacturer is LGC (LG Chem (?))
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=50ba571c-a873-4932-96e8-acf9e20af1bf)
    I reinstalled Windows 10 a few months ago so it starts from April, but it actually starts from a year ago
    Maybe its batteries from SIMPLO
    But of course Microsoft should be giving a replacement battery without charging so much?
    Will keep an eye on the battery levels and post updates if it suddenly goes down
