2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-03T22:21:41+00:00
    to those that recommended i go to page one ....and read most helpful reply...
    I have!
    My request is for all of us here to be kept in the loop............even if having issues but still working to find a resolution......but 8 days since and NOTHING
    throw us a bone MS please
    2016-08-03T21:17:18+00:00
    My battery output shows 100% charged with 1 hour of battery life remaining. But after the device is unplugged in minutes the charge quickly  goes from 100% to 60% with 30 minutes of battery life remaining and within a few more minutes it goes to 40% of battery life with 10 minutes of battery life remaining. The puzzling thing is the device says the battery is 100% charged but at 100% only 1 hour of battery life registers then the battery actually dies in minutes.
    What a piece of junk.
    2016-08-03T20:17:01+00:00
    Microsoft has no right to treat its customers like this. They have taken money for defective products and should be doing everything possible to keep people fully updated on how they are going to resolve the fault.
    This has probably been linked to here before, but probably worth posting the actual text to keep it in people's minds. Given that we are being given absolutely no feedback from Microsoft about how or when this issue will be resolved please contact these people to get the class action underway.
    Migliaccio & Rathod LLP is investigating reports that batteries in Surface Pro 3 laptops are holding almost none of their charge. Consumers have relayed that the laptops, which have Simplo batteries installed, substantially and progressively degrade over time to the point where they are virtually nonfunctional.  While all batteries can be expected to experience reduced performance as they age, the problems that plague Simplo batteries are far worse and appear to only be remedied by a repair costing in the neighborhood of $500.
    *Almost every state (and the District of Columbia) has a consumer protection statute that broadly prohibits unfair and deceptive trade practices. If the reports about the Surface Pro 3 batteries prove true, our law firm believes that the sale of the laptops with the defect may have constituted an unfair and deceptive trade practice that may entitle a purchaser to relief. The attorneys at Migliaccio & Rathod LLP have successfully prosecuted several consumer protection class action cases, including a case against Lenovo involving defective laptops, which resulted in a classwide settlement. (Disclaimer: past successes do not guarantee future results). If you are an owner of the Surface Pro 3, and have experienced significant battery life issues, please contact our attorneys at ******@classlawdc.com or *****@classlawdc.com for a free consultation. You can also call our office at 202-470-3520.
    2016-08-03T19:56:28+00:00
    ...and in reference to my surface's battery degradation and the information you are collecting on your own site, here's the pertinent information from my device:
    Installed batteries
    Information about each currently installed battery
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1164712452
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 8,922 mWh
    CYCLE COUNT 444
    Battery capacity history
    Charge capacity history of the system's batteries
    2015-11-23 - 2015-11-30 40,474 mWh 42,157 mWh
    2015-11-30 - 2015-12-07 40,372 mWh 42,157 mWh
    2015-12-07 - 2015-12-14 40,494 mWh 42,157 mWh
    2015-12-14 - 2015-12-21 40,365 mWh 42,157 mWh
    2015-12-21 - 2015-12-28 40,192 mWh 42,157 mWh
    2015-12-28 - 2016-01-04 39,660 mWh 42,157 mWh
    2016-01-04 - 2016-01-11 40,418 mWh 42,157 mWh
    2016-01-11 - 2016-01-18 40,679 mWh 42,157 mWh
    2016-01-18 - 2016-01-25 40,801 mWh 42,157 mWh
    2016-01-25 - 2016-02-01 40,689 mWh 42,157 mWh
    2016-02-01 - 2016-02-09 40,673 mWh 42,157 mWh
    2016-02-09 - 2016-02-15 40,995 mWh 42,157 mWh
    2016-02-15 - 2016-02-22 40,645 mWh 42,157 mWh
    2016-02-22 - 2016-02-29 40,961 mWh 42,157 mWh
    2016-02-29 - 2016-03-07 41,061 mWh 42,157 mWh
    2016-03-07 - 2016-03-14 41,567 mWh 42,157 mWh
    2016-03-14 - 2016-03-21 42,398 mWh 42,157 mWh
    2016-03-21 - 2016-03-29 39,421 mWh 42,157 mWh
    2016-03-29 - 2016-04-04 41,769 mWh 42,157 mWh
    2016-04-04 - 2016-04-11 42,583 mWh 42,157 mWh
    2016-04-11 - 2016-04-18 42,583 mWh 42,157 mWh
    2016-04-18 - 2016-04-25 42,583 mWh 42,157 mWh
    2016-04-25 - 2016-05-03 42,583 mWh 42,157 mWh
    2016-05-03 - 2016-05-09 42,583 mWh 42,157 mWh
    2016-05-09 - 2016-05-16 42,583 mWh 42,157 mWh
    2016-05-16 - 2016-05-23 42,583 mWh 42,157 mWh
    2016-05-23 - 2016-05-31 39,570 mWh 42,157 mWh
    2016-05-31 - 2016-06-06 35,261 mWh 42,157 mWh
    2016-06-06 - 2016-06-13 30,531 mWh 42,157 mWh
    2016-06-13 - 2016-06-20 27,406 mWh 42,157 mWh
    2016-06-20 - 2016-06-27 24,615 mWh 42,157 mWh
    2016-06-27 - 2016-07-04 22,476 mWh 42,157 mWh
    2016-07-04 - 2016-07-11 22,128 mWh 42,157 mWh
    2016-07-11 - 2016-07-18 15,896 mWh 42,157 mWh
    2016-07-18 - 2016-07-25 13,743 mWh 42,157 mWh
    2016-07-26 12,310 mWh 42,157 mWh
    2016-07-27 11,818 mWh 42,157 mWh
    2016-07-28 11,748 mWh 42,157 mWh
    2016-07-29 11,379 mWh 42,157 mWh
    2016-07-30 11,134 mWh 42,157 mWh
    2016-07-31 11,134 mWh 42,157 mWh
    2016-08-01 10,314 mWh 42,157 mWh
    2016-08-02 9,216 mWh 42,157 mWh
    And since I ran this report yesterday and the report is discontinuous after the update, my current reported capacity is 8,345mWh (yes, I've lost another Wh overnight!)
