2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-03T17:59:36+00:00
    thanks
     i would only  need a usb to ethernet hub  then as i require hardwired internet  as wifi is no good for me
    2016-08-03T17:52:48+00:00
    I've just done the anniversary update which went fine as the device was plugged into AC.
    HOWEVER!
    The battery report (from "powercfg /batteryreport") has wiped out the historic information about battery capacity degredation. Other historic information is largely wiped out as well, although some basic information such as cycle count remains.
    If you're on this forum, I'd make sure that you save your historic information to help substantiate any claims for performance degradation that you may need to make, either via your retailer or through Microsoft directly. I will have to pursue my claim through my retailer (which will be fun, I imagine) as I did not purchase from Microsoft.
    Good retailers should know what to do in this situation. I have had excellent customer service from Amazon UK when I've had a similar situation with another piece of expensive out-of-warranty equipment that failed, with a replacement in days.
    I'm disappointed with the level of interaction from Microsoft on this. The number of affected users may be small, but that should make it simpler to either engineer a specific fix for the affected hardware or to offer a replacement device(s).
    I haven't been able to find any simple method of contacting Microsoft directly (in the UK) via electronic means, but if you feel that Microsoft have acted unreasonably, the address that customer support gave me to write to when I raised the UK Sale of Goods Act is:
    Microsoft Legal Department Microsoft Thames Valley Park Reading Berkshire
    RG6 1WG
    Please address the letter to "Microsoft Corporate and Legal Affairs" and make sure it includes:
    1. Reference number (Case number you would like to be forwarded)
    2. Your name
    3. Your best contact phone number
    4. Preferred contact time in overall
    5. Best contact e-mail
    6. Return address
    7. Preferred contact method (phone, e-mail?)
    (All text and emphasis provided by the Microsoft support representative)
    If you bought your device in the UK from Microsoft and are getting stonewalled on a solution by support if your device is out of warranty then this may be a useful recourse.
    Of course, all of these busted devices, through whatever route, will end up back in Microsoft's hands, so it would be far better for them to start communicating with us!
    2016-08-03T17:51:11+00:00
    i have the LG battery  still 29k charge capacity but 8% plugged in not charging it has been unusable without power cord  since feb when it was 97% plugged in not charging ,it only works in the Docking station until the fan comes on then the ethernet goes off
    i have reinstalled windows 8 then upgraded to windows 10 last week  and no difference  it will not allow me to install updates as it is not 40% charged
    NAME X883815
    MANUFACTURER LGC-LGC
    SERIAL NUMBER 1154881796
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 29,518 mWh
    CYCLE COUNT 57
    Then you are experiencing the stupid battery algorithm bug, not the SIMPLO dead battery issue.
    You should follow the "Plugged in, not charging" steps on this link: https://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/surface-wont-turn-on-battery-wont-charge?os=windows-10
    2016-08-03T17:45:54+00:00
    NAME X883815
    CHEMISTRY LION
    CYCLE COUNT 57
