2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-03T16:13:39+00:00
    Just a update on mine. I can no longer use the surface 3 pro in the docking station. it will power on and a few moments later just turn off. I can still run it off the charger that came with it, but this is a pain because now I have to get a usb hub, a usb network adapater and a mini display port to display port cable so I can use it with my monitor and network. The dock is now useless because of this battery issue.
    The problem with the dock is it does not supply sufficient power to charge the tablet and run the peripheral ports, when the tablet is utilizing a lot of CPU, such as playing a video, or booting up. Furthermore, the dock is simply not charging the battery when the Surface is shutdown, so the catch 22 is to get the surface started up before the battery dies, long enough for the battery to start to charge, when there's insufficient charge in the battery to complete the startup process.
    What I found as a workaround, was to plug the Surface into the portable power connector, then startup and log in. I then leave it to sit there while the pathetic charge level reaches over 50%, which only takes minutes. Then, shutdown and remove the cord. Immediately transfer to the dock, with all peripherals disconnected. Startup and login, there should be just enough juice to get to a fully booted and logged in state. Don't start to use it yet. Wait for the battery to charge to over 90% and slowly add peripherals.
    I dragged the battery indicator from the hidden icons tray to the start menu, so I can see it charging and the current charge level. If it drops below 30% it will simply turn off, so I limit CPU usage by closing apps I'm not using, including the system tray apps. I also close browser tabs and avoid videos. When I do play a video, I keep an eye on the battery indicator.
    It's a pain in the butt, but with a pathetic 144 mWh battery charge, I can run a mouse, keyboard and 2 displayPort monitors with WiFi. If I play videos, the battery instantly drops and begins charging, but the CPU may be drawing more power faster than the battery can charge and the surface will shut off after too long. If the Surface fan kicks in, I need to close my apps, because the Surface is about to turn off.
    I hope this helps. It's a bad situation and turned a fast boot tool into a long winded game of Russian roulette, but I have managed to get my dock to work with a dead battery.
    2016-08-03T15:54:50+00:00
    I just finished the update and firmware update everything went fine. So far no change with the battery.
    2016-08-03T15:49:25+00:00
    "Antony/Everyone
    has anyone with the SIMPLO battery issue been able to upgrade to the Windows
    Anniversary Upgrade successfully using Windows Update? (Go to settings, Updates
    and manually check for updates). There is NO fix there for the issue, but I'd
    like to know if the battery degradation is"
    If all this upgrade is going to do for me, is erase the evidence of my battery history and prevent further history being available, why would I even attempt it?
    What sort of an update gets pushed because of an anniversary, anyway? Is that like Microsoft celebrating an anniversary of something, by actually applying a bug fix to something that has an anniversary of being broken?
    There are some strange trains of thought going on at Microsoft, that's for sure. Still, many of Microsoft's products have been overly complex and unituitive, for as long as I can remember.
    2016-08-03T13:46:29+00:00
    If this fix were true, many of us here (including myself) who primarily use a docking station would never have had our batteries degrade in the first place.   Fortunately, Microsoft replaced my SP3 and the new one is working fine---for now.
