2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-01T22:20:33+00:00
    Just installed the latest firmware (1/8/2016), battery is still showing 100% fully charged, whilst it is only 16k mWh out of 42kmWh design.
    I will use it down to 95% and try to charge it back. I know this is pretty risky because every time I use the battery, it degrade by 5% or so...basically it stops charging at 95% of whatever capacity is left. But if I turn off the computer and restart, battery status will show 100%.
    oh wow...just unplugged and battery drops to 91% within 10 seconds...then 88% after a few more seconds. seems to be at a rate of 1% per second.
    This could be a good sign - the new firmware may have made the computer realized that the battery was way below 100%.
    It could also be very bad...my battery is just completely screwed now.
    2016-08-01T21:48:47+00:00
    Turned on my Surface pro 3 after a week of not using it and the battery is all screwed up. My surface basically turns off if I unplug it now. Awesome!
    Hope this gets fixed really soon.
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 600 mWh
    CYCLE COUNT 48
    2016-04-24 - 2016-05-02 42,583 mWh 42,157 mWh
    2016-05-02 - 2016-05-09 42,583 mWh 42,157 mWh
    2016-05-09 - 2016-05-15 42,583 mWh 42,157 mWh
    2016-05-15 - 2016-05-25 41,816 mWh 42,157 mWh
    2016-05-25 - 2016-05-29 35,485 mWh 42,157 mWh
    2016-05-29 - 2016-06-05 30,240 mWh 42,157 mWh
    2016-06-05 - 2016-06-12 27,587 mWh 42,157 mWh
    2016-06-12 - 2016-06-19 22,871 mWh 42,157 mWh
    2016-06-19 - 2016-06-26 18,841 mWh 42,157 mWh
    2016-06-26 - 2016-07-03 15,234 mWh 42,157 mWh
    2016-07-03 - 2016-07-10 12,050 mWh 42,157 mWh
    2016-07-10 - 2016-07-17 7,487 mWh 42,157 mWh
    2016-07-17 - 2016-07-24 4,726 mWh 42,157 mWh
    2016-07-25 3,610 mWh 42,157 mWh
    2016-07-26 3,610 mWh 42,157 mWh
    2016-07-27 3,610 mWh 42,157 mWh
    2016-07-28 3,610 mWh 42,157 mWh
    2016-07-29 3,610 mWh 42,157 mWh
    2016-07-30 3,610 mWh 42,157 mWh
    2016-07-31 3,610 mWh 42,157 mWh
    2016-08-01T20:54:34+00:00
    Good thoughtful summary Circusfreak... Some updates from MSFT will go a long way in showing us that they care for the user community. For me personally, the first time I noticed that something was horribly wrong was wen my SP3 went dead in the middle of presenting to client's executive leadership. So that hurt. A LOT!
    2016-08-01T19:53:06+00:00
    Same issue here.
    Contacted support today. Good news is they appear to have gotten the message regarding the product defect. The bad news is when you mention this issue, the phone call gets really weird (very evasive) and ultimately still not helpful.
    Support seemed to be under the impression that this issue started with an update that came out in the last couple weeks. So when I mentioned that my battery had been losing capacity since may, they felt like my issue did not match the problem statement for the corrective update they were going to push - which concerns me.
    Basically they said:
             1. They cannot help me because I’m out of warranty (2 months, nothing strange there)
             2. -IF- I am impacted by this issue, then the solution will be in a forthcoming update, no ETA or details on said update. So… it’s cross your fingers??
    I appreciate the support forum moderator acknowledging the issue and communicating some initial status. I would encourage continued transparency and updates on the progress to it's customers. A great start would be providing a time frame for the update.
    Installed batteries
    Information about each currently installed battery
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1165695492
    CHEMISTRY LION
    FULL CHARGE CAPACITY 3,162 mWh
    CYCLE COUNT 208
    Battery capacity history
    Charge capacity history of the system's batteries
    2016-04-17 - 2016-04-24 42,225 mWh 42,157 mWh
    2016-04-24 - 2016-05-01 42,358 mWh 42,157 mWh
    2016-05-01 - 2016-05-08 41,656 mWh 42,157 mWh
    2016-05-08 - 2016-05-15 37,318 mWh 42,157 mWh
    2016-05-15 - 2016-05-22 33,273 mWh 42,157 mWh
    2016-05-22 - 2016-05-29 29,292 mWh 42,157 mWh
    2016-05-29 - 2016-06-05 28,981 mWh 42,157 mWh
    2016-06-05 - 2016-06-12 31,031 mWh 42,157 mWh
    2016-06-12 - 2016-06-19 28,572 mWh 42,157 mWh
    2016-06-19 - 2016-06-26 24,907 mWh 42,157 mWh
    2016-06-26 - 2016-07-03 20,600 mWh 42,157 mWh
    2016-07-03 - 2016-07-10 16,386 mWh 42,157 mWh
    2016-07-10 - 2016-07-17 11,801 mWh 42,157 mWh
    2016-07-18 9,288 mWh 42,157 mWh
    2016-07-19 8,589 mWh 42,157 mWh
    2016-07-20 8,168 mWh 42,157 mWh
    2016-07-21 7,755 mWh 42,157 mWh
    2016-07-22 7,030 mWh 42,157 mWh
    2016-07-23 6,574 mWh 42,157 mWh
    2016-07-24 6,574 mWh 42,157 mWh
    2016-07-25 5,969 mWh 42,157 mWh
    2016-07-26 4,993 mWh 42,157 mWh
    2016-07-27 4,993 mWh 42,157 mWh
    2016-07-28 4,589 mWh 42,157 mWh
